Tractor Talk Discussion Forum
Purpose of battery box?
Vacherie
02-02-2007 16:02:33
What is the purpose(s) of battery boxes? I have several tractors but no boxes. Do I need the boxes?
Vacherie
02-02-2007 21:58:29
 Thanks for the feed back in reply to Vacherie, 02-02-2007 16:02:33
Lots of reasons for a battery box.
ErnieDD
02-02-2007 18:04:33
 Re: Purpose of battery box? in reply to Vacherie, 02-02-2007 16:02:33
To keep the shrapnel inside if the battery explodes. Just wuz there.
Vibration kills batteries. Bolt 'em down.
Gene-AL
02-02-2007 18:02:33
Vacherie,
In addition to protecting the battery, at least one type of original SA box had two bolts on the inside at the top screwed into the steering wheel/switch panel support assembly and four smaller bolts & nuts on the (outside) bottom of the box to attached the base to the tractor. The box serves as a part of the steering wheel/switch panel support structure. The steering wheel support will be somewhat unsteady without the battery box properly bolted down. BTDT.
John S-B
02-02-2007 16:06:40
It's to protect the battery from dirt, weather, water and getting hit by branches, flying debris, etc. And of course to keep them from bouncing around. What kind of tractors do you have and how are the batteries mounted?
Vacherie
02-02-2007 16:29:01
 Re: Purpose of battery box? in reply to John S-B, 02-02-2007 16:06:40
The tractors I was talking about were Farmall SA, SAV, and C. I use bungee cords. These tractors are mostly for just riding around except the SA which I use for cultivating. Thanks for the feed back.
