Tractor Talk Discussion Forum
john deere b (with pic)
Jonathan S
02-17-2007 14:10:04
hey guys, i have a 1950 jonn deere b that has a leak in the back. i was wondering if anyone could tell me what was causing the leak and if i can buy a gasket to fix it. any input will be very much apreicated. thanks again, jonathan s
http://www.tractorshed.com/gallery/tphotos/a101193.jpg Link
B-maniac
02-17-2007 18:42:21
 Re: john deere b (with pic) in reply to Jonathan S, 02-17-2007 14:10:04
When you go to fix the leak around the pto shaft , you will come across a couple things. First , the housing came with a single lip seal originally. When you order it from Deere you will get 2 identicle narrower seals. Install them back to back , you will get 2 seal lips with space between them. That brings up the other issue. You will probably find a groove worn in the shaft right where the original seal lip rode. You can't expect a new seal to seal against that. The sael lips from the new "double' seal will be positioned in a different location and will miss that groove and therefore seal like new. Make your own housing gasket and you're good to go.
dds-inc
02-17-2007 15:16:30
Looks like a whole bunch of leaks at once. Mostly leaking around the power trol dummy plugss, but I guess the rest could be the power shaft seal, the powr trol valve gasket, or the rockshaft to axle housing. I'd replace them all!
RayP(MI)
02-17-2007 16:21:56
 Re: john deere b (with pic) in reply to dds-inc, 02-17-2007 15:16:30
Might try tightening every bolt on the rear housing of the tractor. Son restored one a while back, and all were suprisingly loose. Leaks seemed to stop after tightening all the bolts.
here
02-17-2007 14:54:51
third party image
