Tractor Talk Discussion Forum
snowblower for 3pth
jaybird-oh
03-11-2007 17:12:37
Guess now that winter is about over I'll start looking for a snowblower for a 3600 Ford.I'd like to get some info from those that use them on what to look for and what width would work best. May be using it on a 961 tricycle also.
RWK in WI
03-12-2007 17:03:16
 Re: snowblower for 3pth in reply to jaybird-oh, 03-11-2007 17:12:37
I have two Ford 3000 gas tractors with 8 speed trans. and live PTO. One has a 6 foot Allied two stage blower on it and the other has a 6 foot Loftness. Both tractors do NOT have loaded tires but have a set of pie weights on them and double ring tire chains. Both tractors also have a ford snow plow on the front as well as front wheel weights. When the snow is deeper than a foot the first pass can require a lot of clutch work but then you can take partial cuts. The blowers make the engines work but do a good job. Neither blower would work on my 860 as the reverse is too fast. I am using an old V style Erskine pullbehind blower on the 860 and it works well. I also use a new style Erskine on a MM and it works great.
rettchr
03-12-2007 06:08:13
If your area to be cleared includes any hills, traction can be an issue. Without 4wd, you will certainly need chains. I had a MF165, with loaded tires and chains-- still had trouble going up my neighbor's hilly driveway. My curent Kubota M5700 with 4wd does better, but it can still spin out too.
A slow reverse gear is also important. If you could use the high range on my MF165, there was not enough snow to make it worthwhile to remove.
Rod in Smiths Falls, ON
03-12-2007 05:29:56
I have used a 60" two stage, single auger on a tractor 66" wide and 37 hp. for the last three years. Only this month did I run into drifts where the extra width of the tractor posed a problem, requiring repeated cuts at the snow from a slight angle.
On the other hand the smaller implement proved a good match for the tractor's power band in very heavy cutting in one two-hour session. The rear tire chains helped break up the hard snow in the tall drifts to make it easier to blow.
Bob N.Y.
03-11-2007 18:11:10
I have an 80" Allied 2 stage, single auger snowblower that I use with a late model MF 65 diesel, 50 pto hp. It is a perfect combo. The tractor is 75" wide overall. A double auger blower would likely be too heavey for a 3600 or a 961. You definitely want a blower that is slightly wider than your tractor.
Michael Soldan
03-11-2007 17:46:23
You need a two stage blower that is the width of your rear tires outside to outside measurement, usually a 5.5 or 6 foot will catch most utility tractors. If you get a lot of deep snow, then a double auger is the way to go, singles work fine, you can always raise them a foot or so and make a cut and then drop them down to clean a swath that is too deep for one pass. I run a single two stage on a 52 HP tractor, only the deepest drifts cause me to make two passes.
