Tractor Talk Discussion Forum
Loader cylindars
Marc in Va
03-12-2007 15:32:10
Hey guys I've got a question. What's the best way to leave a front loader sitting on a tractor? Here's what I mean--when you shut the tractor down and walk away, do you extend the front bucket enough so that water will not pool up inside the bucket (to prevent the bucket from rusting)? It seems like most guys do that. But doesn't that leave the cylinders exposed so they would rust? I like to pull the bucket close to the tractor so that the cylinders are covered. What is best?
Thanks for your help,
Marc in Va
old
03-12-2007 18:04:12
 Re: Loader cylindars in reply to Marc in Va, 03-12-2007 15:32:10
My self when I shut the tractor down I then pull the lift lever to let it fall to the ground then pull the bucket lever to let off any pressure in the system. That way for the most part both cylinders are closed but have no pressure on the system
135 Fan
03-12-2007 15:59:53
If it's a fairly new loader they have hard chrome plated cylinders that rarely rust if they are exposed. Some Older (60's) loaders had cylinders that would rust really bad if exposed. If it's going to sit for an extended length of time, I'd retract the cylinders and try to cover the bucket so it doesn't collect water or take it off and turn it upside down. Look on Cats, they never seem to get rust on the cylinders. A lot of people put the bucket flat on the ground and if your cylinders creep over time it will end up flat anyway. Dave
rrlund
03-13-2007 11:21:51
 Re: Loader cylindars in reply to 135 Fan, 03-12-2007 15:59:53
Don't any of you own a tool shed? :)
