Tractor Talk Discussion Forum
MF 1100-510 engine swap
Logan
03-23-2007 08:26:17
People have told me that this wouldnt work because the adapter plate wouldnt bolt up, but i have the adapter plate and water pump on so far but the intake and exhaust manifolds have different holes in the head. I was told i should be able to redrill the head. any ideas?
super99
03-24-2007 04:26:01
 Re: MF 1100-510 engine swap in reply to Logan, 03-23-2007 08:26:17
Can't help you much on a 1100, but I took a Perkins out of a 750 and put it in a 1850 and I ran into the same thing with manifolds. Ended up using 750 manifolds and turbo and built exhaust to fit turbo and used 750 air cleaner. Can you use head off of 1100? If not, I would take it to a machine shop and have it drilled right and then it should work. Chris
