Tractor Talk Discussion Forum
allis wd tranny flush?
hammerfer
03-31-2007 10:10:42
Hi, I finally got around to draining all the fluids on my 52 wd. I knew water was an issue since it sat for years without a shifter boot on it. The fluids came out super milky which is expected, but should I flush it with something or fill it with 80w and run it all summer and change it again in the fall? Thanks for your help with this.
Donnie Baker
03-31-2007 10:23:08
 Re: allis wd tranny flush? in reply to hammerfer, 03-31-2007 10:10:42
Hey man fill the transmission rearend with diesel fuel and drive it around some to mix/rinse the internal parts, drain and refill with gear oil, I gotta go
hammerfer
03-31-2007 15:29:54
 Re: allis wd tranny flush? in reply to Donnie Baker, 03-31-2007 10:23:08
I was thing about using diesel fuel, the one worry I had was if there was some left in pockets in the transmission would it break down the 80-90w gear lube?
janicholson
03-31-2007 10:18:46
I would put a mix of ethanol (or isopropel alcohol) and diesel in the trans then jack one wheel and block it to idle the system for 5 min. Then drain for two hours and fill with new gear oil. JimN
