Tractor Talk Discussion Forum
Tire trouble
Devin Sparks
04-16-2007 20:20:13
I have a tire that I had repaired this week. I ran over something while running the bush hog. The repair was a patch and new inner tube. I now have a 1/2 inch hole where the tire was cut. Is there anything that I can put in the hole to prevent a rock or stick from punching thru. I was thinking of epxoy. Any ideas?
Leland
04-19-2007 19:20:47
 Re: Tire trouble in reply to Devin Sparks, 04-16-2007 20:20:13
they make a patch plug for this ,it looks like a regular patch with a built on plug
msb
04-17-2007 05:47:21
gemplers.com They have a product that you stitch in the hole with a tire patch wheel.You will hardly be able to see it.Great stuff.
Bill in NorthCentral PA
04-17-2007 05:33:30
I fill mine with whatever partial caulk tube I have. Seems to hold and I call the price free in that the caulk would go bad sitting in the tube.
RayP(MI)
04-17-2007 04:48:41
Had a tire with a nasty gash in it. Took it to tire dealer/recapper. They put a large boot (patch) inside, and then revulcanized hole from outside. Patch has held several years, have to look for where it was, looks that good. Cost $68. Money well spent.
Keith-OR
04-16-2007 21:01:35
Go to you auto glass shop and get some windshield urathane, fill the hole.
PS sometimes the glass shop has some urathane left over in the tube and will give it to you.
Keith & Shawn
Stumpalump
04-16-2007 21:13:28
 Re: Tire trouble in reply to Keith-OR, 04-16-2007 21:01:35
I use a urathane like stuff called Shoe Goo. Its made to repair or build up the bottom of worn out tennis shoes. Sporting good stores sell it.Almost the same stuff can be found packaged to repair hunting waders and air matreses. Good for all kind of stuff. Another thing that is amazing on rubber is super glue. Super glue and ruber are a match made in heaven but I only used it to glue up big cuts in Super Swamper tires that didn't go all the way thru.
Walt Davies
04-16-2007 20:58:01
Take it to your tire dealer they can send it out and have it sectioned I had it done on two tires its a small cost about $25 but it make the tire as good as new.
Walt
Keith-OR
04-16-2007 21:03:19
 Re: Tire trouble in reply to Walt Davies, 04-16-2007 20:58:01
Walt you are quicker on the key board than I am tonite...:>)
Keith
Walt Davies
04-17-2007 08:45:54
 Re: Tire trouble in reply to Keith-OR, 04-16-2007 21:03:19
Kieth I can't believe some of the things people are suggesting Shoe-Goo and such. its a small cost to fix a $600 tire the correct way.
Blow out a tube and loose the stuff that you are using for weight will cost more than the fix. Walt
old
04-16-2007 20:51:51
I don't know if you can still get them but at one time they made a tire liner. It covers the in side of the tire and is about 1/4-1/2 inch thick and will pretty much stop any thing other then iron. Other thing you can do is get a tire boot and glue it on. Either way I would at least boot it and if you can find a liner also
johndeereman
04-16-2007 20:45:44
bolt a patch on cut a piece out of an old tire then bolt it over the inside of the hole with carriage bolts
Devin Sparks
04-16-2007 22:00:31
 Re: Tire trouble in reply to johndeereman, 04-16-2007 20:45:44
Thanks for the advice. It was patched and refilled with water. Maybe I will try the urathane idea.
