Tractor Talk Discussion Forum
weight of a 1086
D17 man
04-18-2007 19:55:23
does anyone know the weight of a farmall 1086? im goin to look at one tommarow and we"re bringin a one ton duramx and a gooseneck rated for i think 14000 pounds. i"ll post some pics if i end up getting it.
the tractor vet
04-19-2007 07:13:11
 Re: weight of a 1086 in reply to D17 man, 04-18-2007 19:55:23
Never ever go by DRY shipping weight , And does this 10 have 18.4x38' or did someone upgrade to 20.8x38 's . Tires loaded extra wheel weights ft. weights extra fuel tank . And you want to put this on a 14000 lb trailer , I don't thinks so . A 1086 can be more then ya want on a 20000 lb. tanden dual as that trailer will weigh in over 7000 and if that can goes over 16000 and they can go over the 16000lbs your over . Yea ya may get away with it i have hauled 10'and 14's on my tandem dual and one 1570 case and only one of them never again . Heck my 806 goes 11960-80 on the local scales and has bumped over 12000 and it is a tric. with no ft weights on it just loaded tires add in a 1000 on the nose and put five sets on the rear and where ya at.
SD pete
04-19-2007 05:42:50
My uncle had one and it was about 15,500 on the elevator scale.
RustyFarmall
04-19-2007 04:24:01
I own a 14,000# rated trailer. The shipping weight on the trailer is 5,200#, which leaves 8,800# that you can haul on the trailer. I know that a certain percentage of the load you put on the trailer is actually transferred to the truck, so you can probablt exceed that 8,800# and still be OK, but the 1086 will still be way too much for that trailer. A 20,000# rated trailer behind that same dually would get the job done.
Paul from MN
04-19-2007 03:30:41
D17, Is your trailer rated to carry 14K or is the GVWR 14K. If the latter, remember your trailer probably weighs 4k, leaving you 10k for the tractor.
Allan In NE
04-18-2007 23:44:51
Boy, I dunno.
If it is dualed and weighted up, it could crowd 15K lbs awful easy.
Allan
IaGary
04-19-2007 03:16:58
 Re: weight of a 1086 in reply to IHC Red, 04-18-2007 20:23:40
Allan and IH Red are both right.
Shipping weight with no fuel is just under 12,000. You add fluid to the tires put on dauls and weights and you can get them up to 16,000.
Back in my tractor pulling days I could pull in the 12,000 lb. class and clear up to the 16,000 lb class.
Gary
