Tractor Talk Discussion Forum
OT/ Log Chinking (old method)
NE IA Dave
04-19-2007 21:59:46
I have a project of chinking a real old log cabin that was re built. Please do not confuse with every company offering products that are designed for the wealthy and dollar foolish folks.
I'm interested in the old way of doing it, not back as far as sod or mud , but rather mortar type mix. Also what type of filler can we use. I have found a backer in six inch size, but the dang fools get two dollars a running foot for it. These logs have a gap of min 2" and probably 6" or 7" max. The logs have been pressure washed. Can anyone point me in the right direction? I have plastered up many rock walls with mortar. We thought perhaps chicken wire stapled in the cracks would help reinforce the joint, and maybe running in some screws part way in the log would anchor the mixture.
Thanks in advance.
Richard G.
04-20-2007 05:50:34
 Re: OT/ Log Chinking (old method) in reply to NE IA Dave, 04-19-2007 21:59:46
My son lives in log house he finished in 2002. He put lots of 8 penny nails in the cracks and chinked with his own mixture of red clay, blue creek clay, mortar mix and a little bit of portland cement.
It looks great and is very tough.
Make sure you slope the chinking in at the top and out to the edge of the log at the bottom to shed water.
Richard
Brian in Ohio
04-20-2007 05:36:52
third party image
I don't know how clear the cabin in the background will be, but if you shoot me an email, I can put you in contact with the gentleman that was responsible for taking down, and reconstructing this one. He is an expert, and has done three of these so far, with one of them being an addition to his own house.
RMinVa
04-20-2007 04:07:35
We had 7 tobacco barns on our farm and 5 were log barns. After tobacco went down hill we sold the barns to an outfit in WVa. All of the barns had wood chinking. Three of the barns were built from 1913-1916. All the chinking in those three were nailed in with cut nails. The other two barns we had no idea when they were built but the chinking had wood pegs. I didn't know this until the barns were taken down. But I do remember those two barns, we never had any problem with the chinking falling out. The pegs held tighter than the nails.
Some of the chinking looked to be outside cuts from logs that were cut at a saw mill. Looked to be from the first cut when squaring the logs up. Some had the bark still on it. Then were split to fit between the logs and were almost triangle shaped.
The barns with the pegs had white dirt from one place on the farm that had that type dirt. This dirt was also used for whitewash. It would dry natural white. The white dirt was mixed with horse/mule hair and worked wet for the dobbing. The other barns we used red clay for dobbing. That had to be done almost every year but the white dirt dobbing was still in the older barns when they were taken down.
I'm sure different areas used different styles and different materials. What ever they had available in the area. Plus what part of europe they came from dictated they style they used.
Forgot to say all the loges were hand hewded/hewn (sp) The reason I know when the three barns were built is I talked to a gemtleman that help build those barns. He was born in 1900. He said the barns that had to wood pegs were already aged when he was working on the new barns.
Walt Davies
04-19-2007 22:24:49
My grandfather built a 40 X 40 log store that is still in business today. He used mortar to chink it. he always used lime that had been put in a large barrel and water added to make it into quick lime. then you add a very small amount to the mortar. this will give it strength and make it last forever. Chicken wire will rust and cause a problem later on. Walt
JOHN HARMON
04-19-2007 22:23:55
My GGrand Parents were awarded Homestead rights as Grand Dad was a Civil War Veteran to a small holding of Land in Kentucky. The first Building done was a two Room Cabin of log Construction. The "Chinking "used was comprised of several elements. Some Tree Bark ,some Tree Wood slivers and Moss, and other things were used to Chink in between the Logs as needed. all these different fillers for the cracks between the logs was Plastured with a Bank Run Clay,Wood Ash,Salt and Animal Grease mixed together to form a Stucco.This Plaster was in side and out over the Log Joint.The Homestead stood until after 1933 when Grandma died and the place was sold to another party.The Cabin was heated with a small Wood burning Stove which over heated and set the House on Fire. No one knew that a Case of Dynamite and Fuse were stored in the Attic and when the Fire got to the Attic a huge Explosion occured and no more Homestead and about 5 less members of that Family who were standing around watching the Fire burn. This happened in 1935 and I was born just down the road in 1937 and as a little Kid I remember the Stories of when Grand Dads House blew up.
