Tractor Talk Discussion Forum
Help: Allis WD leaking gas
tractormiallis
04-21-2007 18:00:21
Got done running WD today, parked it and went away, came back and it is leaking gas from the carburator. Turned shutoff off, then that started dripping gas. What is the problem with it? Im stumped as to what is wrong.
RAB
04-22-2007 00:52:25
 Re: Help: Allis WD leaking gas in reply to tractormiallis, 04-21-2007 18:00:21
Possibly blocked vent in tank cap. Gas warming up and pressurising the system?
Regards, RAB
Delta Bob
04-21-2007 18:50:46
It may have some trash under the float needle. Crank it and then shut off the gas while it is running and let it go dead. Turn the gas back on, with the float down the flood of new gas will usually wash out the material under the needle.
Jeff McBride
04-21-2007 18:05:25
Sounds to me like the float in the carb is stuck.
tractormiallis
04-21-2007 18:50:25
 Re: Help: Allis WD leaking gas in reply to Jeff McBride, 04-21-2007 18:05:25
Would the float make it leak out of the shutoff also?
Jeff McBride
04-21-2007 19:22:14
 Re: Help: Allis WD leaking gas in reply to tractormiallis, 04-21-2007 18:50:25
No the float would not make it leak at the shutoff. That is more than likly another problem, you may need a new shutoff.
