Tractor Talk Discussion Forum
Starter problem
kyle in NY
05-17-2007 15:34:02
Is there a way to tell if it is the starter that is bad or the solenoid? The starter sounds tike its spinning but not engaging. Any ideas? Thanks, kyle
Jiles
05-17-2007 18:59:33
 Re: Starter problem in reply to kyle in NY, 05-17-2007 15:34:02
Could also be stripped flywheel.
MSM
05-17-2007 15:58:13
If it is indeed spinning,the starter and solenoid are OK. The Bendix drive on the end of the starter shaft is either bad,stuck or stripped. Just clean and lube or replace the drive,not the whole starter.
Walt Davies
05-17-2007 16:08:22
 Re: Starter problem in reply to MSM, 05-17-2007 15:58:13
Never Ever lube Bendix on starter. Clean it with Brake clean and dry it off or it stick when starting the engine.
Walt
Ron Remy
05-17-2007 20:13:04
 Re: Starter problem in reply to Walt Davies, 05-17-2007 16:08:22
check the splines on the starter shaft , maybe remove drive and lube splines so it slides freely. Don't forget the bushings too,If your drive has a band around the clutch rollers, soaking in motor oil overnite might loosen up stuck rollers. They are assembled with light grease at the factory , and may get dry and stick.
john in nebraska
05-17-2007 15:55:47
If the starter spins without engaging the flywheel, the starter drive, aka the Bendix is bad, and needs replacing. The starter won"t spin at all if the solenoid is not working.
kyle in NY
05-17-2007 16:15:21
 Re: bendix in reply to john in nebraska, 05-17-2007 15:55:47
Where can I find a new bendix drive? Are they easy to find?
Thanks
RayP(MI)
05-17-2007 17:47:48
 Re: bendix in reply to kyle in NY, 05-17-2007 16:15:21
Most any auto parts store.... NAPA, etc.
