Tractor Talk Discussion Forum
tire pressure in duals
R.J.
05-18-2007 16:46:49
Have 20.8 by 38 duals what pressure should be run in these, also should the outside tire have slightly less than the inside tire?
Thank you,
buickanddeere
05-19-2007 05:41:44
 Re: tire pressure in duals in reply to R.J., 05-18-2007 16:46:49
Engineers have spent millions on testing with calibrated equipment to find out the ideal operating parameters for pneumatic tires. I'd take the tractor info on the Firestone AG site over Bubba's opinion down at the diner.
Walt Davies
05-19-2007 11:47:11
 Re: tire pressure in duals in reply to buickanddeere, 05-19-2007 05:41:44
Now you know Ol' Bubba knows more than those Lazy Engineers down at the Factory.
Walt
dds-inc
05-18-2007 19:50:35
half pressure....If you put full pressure on the outside wheels, you will increase your chances of axle bearing loss significantly.
JoeBob/IN
05-18-2007 19:38:04
I just read on one of the tire manufactures sites that the old thinkin was to have a few less psi in the dual tires but now to run equal amounts in all. Are they bias or radials. What is the load per tire... what tractor and what kinda equipment (pull type or mounted)? It all depends. No less than 12 psi if bias tires but you could need near 20 psi with large equipment. Possibly as low as 6 psi with radials! All depends so let me know and I can probably calculate for ya but when you change useage of tractor, like taking off duals or going from draw bar pull to 3 pt you will have to adjust psi!
flying belgian
05-18-2007 17:42:52
I was always told to run half pressure in the outside tires.
