Tractor Talk Discussion Forum
JD 4320 fenders
Farmerzc
05-25-2007 13:25:20
Does anyone know if the 4320 has the same size fenders as the 4020? If so, any one know where to find a set of them? Thanks for the help.
Leland
05-26-2007 05:15:29
 Re: JD 4320 fenders in reply to Farmerzc, 05-25-2007 13:25:20
www.sloanex.com plenty of after market tractor and combine parts
Glen in TX
05-25-2007 23:14:06
Like said different because of tire size and seems like fender is longer or cast bracket taller. Most 4320s came with 18.4-38 in this area and 4020s with 18.4-34. You need to the 38s on the 4320 anyway. You can view those for 4320 and others mentioned to compare in JD online parts catalog. Salvage dealers: adeptr.com (parts then state).
Dean Barker
05-25-2007 20:56:16
According to the advertising literature, 4320's came with both the 4020 and 4620 style fenders depending what tire size the tractor was ordered with. I'm assuming that the larger tires required the 4620 style fenders and the smaller tires required the 4020 type fenders. I have not found a tire/fender chart anywhere, however there may be one.
onefarmer
05-25-2007 16:38:41
I put a 4020 fender on my 4320 and it is too close to the tire. I'm going to have to build a spacer to raise it some. Go with the correct ones the first time.
MSM
05-25-2007 16:27:07
4320 fenders are a little larger around the wheel opening and longer.You should be able to find a good set in a salvage yard,same fender is used on 43,45,4620
