Tractor Talk Discussion Forum
Tore one of the gaskets on the bottom of the oil p
Mark Doud
05-28-2007 17:23:07
I was putting my Super C oil pump back together and one of the two bottom gaskets that goes between the oil pump and the bottom plate tore in two. Will this still work or should I replace it with another one? (both are new)
After I put a little grease on the metal surface and pressed the two paper gaskets onto it the tear all but disappears.
Thanks in advance!
Mark D.
Dave_Id
05-28-2007 17:29:22
 Re: Tore one of the gaskets on the bottom of the o in reply to Mark Doud, 05-28-2007 17:23:07
Replace it, you"ll be glad you did. If you don"t, then for sure it"ll leak.. never fails.
