Tractor Talk Discussion Forum
Smoking Carborator
Lanse
06-27-2007 18:41:06
I bought an old Snapper Comet 30 and have had to do some work on it.
The carborator-yep-smokes. Grey smoke from a Briggs&Stratton carborator. Can anyone help me? It comes off the side nearest the engine block.
I am also looking for a Briggs air filter for the tractor. Just like the motor oil, it appears to be orignal =)
old
06-27-2007 19:21:16
 Re: Smoking Carborator in reply to Lanse, 06-27-2007 18:41:06
A lot of those have the oil/crank case breather going to the carb and if it does then most likely thats where the smoke is comeing from. Do you need another one for parts?? I have one but it has the tecumse engine on it. I brakoe the crank shaft right where the flywheel is bolted down on it. Sure would like to see it go to some one that could use it for parts
LAnse
06-28-2007 12:08:57
 Re: Smoking Carborator in reply to old, 06-27-2007 19:21:16
I may. Where are you at? What do you want for it?
Dont e-mail me-it dont work.
old
06-28-2007 14:48:57
 Re: Smoking Carborator in reply to LAnse, 06-28-2007 12:08:57
I'm in missouri. By the way that crank case breather has a little sort of check valve in it and if its not working right it can cause that type of problem also
