Tractor Talk Discussion Forum
OT: ‘73 Chevy C-30 Dump Truck Hydraulic Pump Cable
Blur3992 (N Ill
07-01-2007 19:36:54
I recently picked up a 73 Chevy C30 with a dump bed on the back. The bed is hydraulically lifted, with a PTO powering a hydraulic pump.
Right now, there is no way to control the pump. There's a lever on the pump that has about 4 inches of travel, going two inches either way from a center detent. Also, there is a small 3/4-inch hole in the floor near the shifter. I assume that there is supposed to be a control cable that mounts in the floor to connect to the lever on the pump.
Is there a specially built cable for this sort of thing? The thickest control cable that Farm and Fleet had was still pretty flimsy. I know I could probably make it work, but it would be nice to have the proper part.
J Schwiebert
07-02-2007 08:39:18
 Re: OT: ‘73 Chevy C-30 Dump Truck Hydraulic Pump Cable in reply to Blur3992 (N Illinois), 07-01-2007 19:36:54
If you have a Chelsea PTO the shift covers are different for mechanical linkage and the cable control. If it is a Chelsea post the model number and if nobody changed it so it corresponds with the model number on the tag I can get you the details.
Gerald J.
07-01-2007 20:17:16
Look at Baum Hydraulics. They have most any length and are sturdy enough to run the PTO shifter as well as the hydraulic valve.
www.baumhydraulics.com
Gerald J.
matthies
07-01-2007 19:55:21
Go to any truck repair shop and ask for a pto control cable. Shouldn't be to hard to find, maybe a Napa store should have one. chris
Clint Youse MO
07-01-2007 19:43:40
OUR 69 and 61 both have solid lnkage from the pump to a handle that comes up through the floor no cables
