Tractor Talk Discussion Forum
massey harris 44
roger roland
08-02-2007 19:43:28
just wondering a little about the things as i am a ih & jd person . a buddy of mine gots one or wont have long, he is a junker (sad but true ) just got it in on trailer tonight said its going in on monday mornings iron inless i want it looks rough, has wide frt under it looks kinda like ih but also like jd wide dont know has a strate flat head eng . is this correct or someone put that in there ? call me stupid lol is it worth anything as parts to anyone befor going to iron ? ill probly pull the frt end off it for sure... 250 will probly buy the whole thing as thats iron price he said located in north east nebr
noncompos
08-03-2007 10:37:34
 Re: massey harris 44 in reply to roger roland, 08-02-2007 19:43:28
That Cont F226 was used in a ton of stuff; it"d be a shame to let it get away.
Janicholson
08-03-2007 09:29:29
In the late 70s I* had a neighbor that pushed about 3000hp (that is the correct #) through the rearend of a 44. It never broke. he had 2 500+ CID chevies one running twin turbos one w/8-71 blower with 30% od. The rear engine had a Crankchaft Co. Billet Crank, and he was pulling across the USas a national contender (appearance money). Sassy Massy was the tractors name. JimN
George G
08-03-2007 08:37:46
Where you at? I have a 44-6. Could always use one for parts, or repair.
RustyFarmall
08-03-2007 04:16:38
You need to save the entire tractor. That wide front end is worth some money, and there may be other parts that are in demand. It is worth more parted out than what the scrap iron price will be.
Dave H IA
08-03-2007 04:13:34
 Re: seiral #'s for it in reply to Traditional Farmer, 08-02-2007 19:43:28
thats a 44-6 ---226 continental engine---more rare than the 4 cyl --less power than the 4 cly----wish it was closer to me
noncompos
08-02-2007 22:55:15
Forgot to add that if that flathead engine (4 or 6?)has any kind of ID tag will see if I can tell how widely it was used. Good luck.
noncompos
08-02-2007 21:57:56
While MH used lots of Continentals, my book (covers 36-49) shows 44 using "own H260G" engine: 4cyl OHV 37/8 x 51/2...a 44K shows for same years with "own H260K" engine, same b/s, looks like all specs in Motor Trk/Tractor book same. There"s also an HD260 engine, but it"s not in my Motor book. Other 44 variations: 44D, 44LP, 44RC used the 260 or HD260 engine but I can"t tell for how long after 49. HTH
old
08-02-2007 21:22:52
Wdie front on it if it sits back and under means its a standrad and can be worth a little more. I know I would try to save it if you have the $$ do so there will never be another one of them made
roger roland
08-02-2007 19:47:34
 seiral #'s for it in reply to roger roland, 08-02-2007 19:43:28
had on tag on side 44 6 GR 3622 just wanted to add that incase someone wanted to know
msb
08-03-2007 05:37:21
 Re: seiral #'s for it in reply to roger roland, 08-02-2007 19:47:34
44-6 GR 3622
Makes it a 1948 G-gas-R-row crop A fairly rare tractor since so many were used to build hot rod tractors out of.
