Tractor Talk Discussion Forum
90 F250 idles at 2400 RPM....whats wrong?
wagsw900
09-15-2007 16:58:57
I have a 90 F250 with a 351 fuel injected engine in it. The prolem is that it will not idle below 2400 rpm. The throttle cable isn"t hanging up. The butterflys in the air intake are closed but it still revs that high. Went to a tractor pull today and trying to shift and back up is nearly impossible. Any more ideas would be great. Thinking it may be the idle air control motor. Wags
jpl
09-16-2007 03:55:59
 Re: 90 F250 idles at 2400 RPM....whats wrong? in reply to wagsw900, 09-15-2007 16:58:57
i;ve got a 92 f250 351 fi, did same thing, i unhooked the throttle position sensor for temp fix to get it to idle down. have to get me new tpi. its easy to unhook as it just unplugs.
SteveKy
09-15-2007 19:31:54
Try the intake gasket where upper meets the lower 99% sure it's sucking air.Common problem on EFI . Steve
RodInNS
09-15-2007 18:55:08
IAC would be my guess, but I don't know too much about them. I had a 302 one time that would require periodic adjustment of the IAC. Sometimes it would idle fast; other times it would hunt and stall. Those were the days before they quite had it figured out I think...
Rod
RobMD
09-15-2007 18:26:12
it could also be your throttle position sensor. Usually these are tied to the cruise control system, and everything else. I'm also recommending you look over all the egr hoses and stuff to make sure that the lines are not dry rotted and such (i.e., vacuum leak).
If your butterfly is shut, I would STRONGLY look for a vacuum leak.
ry
09-15-2007 17:11:04
It might be the IAC. But could also be a big vacuum leak - make shure all your vacuum lines are still hooked up and no leaks on the intake manifold gaskets. I have also seen a faulty TPS cause a fast idle on a Ford. I have been a ford certified master tech since 01 and ASE certified master tech since the Early 90's.
