Tractor Talk Discussion Forum
Dynahoe tractor
CRAIG FENOFF
09-19-2007 04:49:53
Trying to find model number of my Dynahoe. On name plate is serial # 20164 and after model number all I can see is a C stmped in the plate. Was there a model C ? It has a Detroit diesel and is two wheel drive. Also looking for transmission parts. Thanks Craig.
WantACaseLASomeday
09-20-2007 05:10:26
 Re: Dynahoe tractor in reply to 36 coupe, 09-19-2007 04:49:53
Quick Google search for Dynahoe turned up hits for sites with machines and parts for sale and one yahoo groups specifically for Dynahoe owners: Link They should know sources.
CRAIG FENOFF
09-22-2007 05:01:53
 Re: Dynahoe tractor in reply to WantACaseLASomeday, 09-20-2007 05:10:26
THANKS. ILL CHECK IT OUT.
JSharp
09-19-2007 11:47:39
 Re: Dynahoe tractor in reply to CRAIG FENOFF, 09-19-2007 04:49:53
I don't know about the model C, but a friend has a late 60's Dynahoe 200. I'm sure he told me it was a Detroit 4-53 with an Allison trans and that it's made of mostly off the shelf components. I guess the company has changed hands a lot over the years, even being owned by Bucyrus-Erie at some point.
A neat old machine but not dainty, I wouldn't drive near your foundation or over your septic field with it. I think the weight well is over 30,000 lbs...
CRAIG FENOFF
09-20-2007 03:42:15
 Re: Dynahoe tractor in reply to JSharp, 09-19-2007 11:47:39
Thanks for the info.
Tramway Guy
09-19-2007 08:14:59
Dynahoe was a dedicated-purpose TLB (tractor-loader-backhoe)and really well-built for that.
The older ones had Continental gas engines.
The Dynahoe brand was acquired by Terex at some point and parts may be available through Terex.
Some research indicates that your engine might be a Detroit 3-53 series.
I would suspect that Dynahoe purchased transmissions from different OEMS like Clark, Funk, Allison, Twin Disc, etc. Certainly parts are available somewhere...
CRAIG FENOFF
09-20-2007 03:46:59
 Re: Dynahoe tractor in reply to Tramway Guy, 09-19-2007 08:14:59
I heard from a guy that it was probably a wagner trans. Got to take it out one day when I get time. Thanks.
noncompos
09-19-2007 07:50:39
CRAIG FENOFF said: (quoted from post at 04:49:53 09/19/07) Trying to find model number of my Dynahoe. On name plate is serial # 20164 and after model number all I can see is a C stmped in the plate. Was there a model C ? It has a Detroit diesel and is two wheel drive. Also looking for transmission parts. Thanks Craig.
Craig: Oil filter catalogs do list a Model C Dynahoe, apparently a "standard" (no other identification stated) and a second Model C listed as a "ditcher" ; I'm not familiar with Dynahoe, but recall seeing somewthing on Terex that said they "restored" the name or something similar, which I took to mean put back into production, but I have no idea if they still source of parts.Good luck.
