Tractor Talk Discussion Forum
Made a lot of progress (long)
Don-Wi
09-23-2007 23:36:19
I cut all 40 acres of hay on Wed. because the bagger didn't show up yet, then on Thursday morning I chopped 2 loads of corn, and the original plan was to put that in the silo then put the hay on top of it.
I took off the corn head, but had some welding to do on the hay head first so I parked by the fuel tank w/out a head on the chopper. While I was working on the head, the bagger guy called and said he was gonna come in about 2 hours, so during our lunch break we figured I better put the corn head back on, as the hay seemed a little too damp yet anyway.
I finished fixing the head and started helping dad move some stuff around where the bag was gonna go when they showed up, so we kept working while they got the bagger set-up and the wheel switched over, and the rented 986 on it. As soon as the bagger was in position, and before they even got the bag on it, I pulled the 1st load into the field behind the bagger (kinda to say LETS GO ALREADY!!!)
On Thursday I got 9 loads of corn off, 7 of them after 4:00 or so.
Friday had rain in the forecast so we decided to do the hay so I took the corn head off again and put the hay head on while dad hauled out the manure from the barn and spread some gravel in my brother's driveway, and then he emptied me a load from the night before while I greased the chopper. Got started in the field about 11:30, stopped for supper around 5, then went back at it about 6:30. Got all but maybe 4-5 acres off before the rain, or in the rain for the last 1 1/4 loads. 15 loads chopped.
Saturday I got up early and picked pumpkins wiht my brother (3 big truck loads) after finishing the gravel in his driveway and putting another wagon on it for storage. Dad emptied the last 2 wagons I had loaded with hay from the night before, and then I finished off the hay, but only loaded the wagons 1/2 way. I then switched heads over and hooked back onto the wagons and topped them off with corn so the extra moisture in the hay from the rain would mix in with the corn in the bag, so it wouldn't get so sour from being too wet. Fit 5 more loads in the bag and then it was full. Filled the 3 wagons again after a big family supper and called it a night. 8 loads chopped.
Today my fiance and I chased one of my brother's around while he was running a marathon, gave him stuff as he went and took a bunch of pictures. Got home and started in on the farming again around noon or maybe 1. Dad called the bagger guy yesterday to come & get it and that we'd be gone. He came about when we got home from the marathon. We cleaned up the extra feed on the ground, and tied off the bag to let it sit for a couple weeks (and boy was it gassing already)
I helped set up the blower on the other silo with the 1600 on it, and dad unloaded the 1st load from the night before and I was gone again. Got 3 loads off the 1st small field, then went to the one I started on Thursday and got another 3, then came home to finish up those fields and chopped 3 more. 2 loads are on wagons yet, so 10 loads in the second silo so far.
Total load count:
2-3 weeks ago, 1st silo- 10 loads.
Thursday: 9 loads
Friday: 15 loads
Saturday: 8 loads
Sunday: 9 loads
=51 loads total so far.
We still have one small field left that was planted later after taking 1st crop off, but we're gonna use that green stuff to cap off the 1st silo that's full, and then the rest will go in the other silo with the distributer and mix it in a little bit. I expect about 3 loads off that, maybe 4.
Overall we had a good weekend, and I wasn't sure how we'd get it done. I an about 2 1/2 tanks through the 1855 on the chopper, and put on about 30 hours. The 986 we rented used about 1/2 tank of fuel, but I'm not sure how many hours we put on it.
I know 60 acres isn't much land for some of you guys to cover, but for us that's a heckuva lot for us to cover in this short time frame.
I'll probably blow the 2 loads in the silo in the morning, then maybe chop the green stuff on Tuesday or so. We'll be officially done soon enough though.
So far no major break downs which kinda concerns me, as there's always gotta be a catch. The 1855 does have an oil leak on a hard line coming out of the over/under so I've been dumping oil in it (1 qt/tank of fuel) and running it as is for now. I'll fix it later but before plowing. Hopefully I can get the fender tanks hooked up by then too. I'll have the side panels off to fix the line, so I may do it. I just gotta go get the rest of the parts.
All in all, I've probably put about 40 hours on the tractor's myself this extended weekend, which is extraordinary for us. A normal weekend might be 10 hours on any given tractor if we're busy. And my shoulder's killing me...
Donovan from Wisconsin
Dairy farmer in WI
09-24-2007 18:16:58
 Re: Made a lot of progress (long) in reply to Don-Wi, 09-23-2007 23:36:19
yeah. i know the feeling. i been chopping fer everyone else but myself. first i went over and took both choppers to a friend of mine( huge dairy farmer) who had his chopper puke on him for good. he had 5 more 8X200 FT bags to fill plus a 60 ft silo. we put his corn head on my JD and used my IH which already had the corn head on it. had the choppers over there all week. he's now renting a chopper from a dealer so i could get on with my own. was gonna chop a few more loads with the IH. got 1/4 round done and pulgged it and sheared the bolts. then i got that going again then it decided to cut one of the gathering belts. cutter knife got bent somehow and cut it. ok now spend 3 hrs fixing that. it's a good thing i got a parts head. then went to fill the neighbor's 8 X 100 bag sat. and sun. now i got at least 20 loads up the silo today with the Farmitall M on the blower. burned up 3/4 tank in the process but really broke that motor in!. now i got a hold on it since it's sopposed to rain until wed. or thursday.
but that's farming for ya.
Grub
09-24-2007 08:13:56
Gee Don,
You sound like an Energizer bunny commercial. I was the one that was the driving force on the farm. My Dad would push his cap back and look up at whatever load I was hauling/dragging/carrying and say, "Guess you cut a bigger swath than I do". We still chuckle about that. I enjoy reading about your life and work and think you and folks can be proud of who you are and what you can do.
BTW, if it had been me running the marathon you'd still be standing there looking at your watch. You were home by noon?
Grub
rrlund
09-24-2007 07:30:13
I was wondering if you got done. I finished chopping corn Saturday,got the bunker covered with plastic and everything put away. Had 3 loads to go,backed up to lock the extendable tongue on the wagon. When I started ahead,the chopper hit the ground. Luckily nothing was running. The nuts had loostened up where the hitch bolts to the tongue and it just plain fell off. I found out the back of the valve cover gasket leaks on the 1600 when it's standing up on its tail. I was pushing and packing with it and oil ran right out the back when I'd get it to a good angle. Tightened it,but it still leaked some. In fact,it leaked 9 quarts in 8 days. Other than that,just glad to be done. Gotta do a little work on the feed bunks and try to get the calves weaned off the cows this week. Gonna be a few sleepless nights listening to all the bellering.
PJBROWN VT
09-24-2007 06:05:42
how much corn do you guys plant?? You milk cows right?? How many? I milk 60 with my Dad....
Don-Wi
09-24-2007 08:48:04
 Re: Made a lot of progress (long) in reply to PJBROWN VT, 09-24-2007 06:05:42
We only plant about 25 acres every year. on a bad year it's not quite enough to fill both of our silos (12x32 & 16x34) but on a good year we get plenty of extra. The 4th crop was really good this year too and there's no way to get it dry this late in the season so we chopped that off as well.
We milk about 25 cows, give or take. I don't step foot in the barn much anymore, but I still do all the field work.
PJBROWN VT
09-24-2007 09:08:20
 Re: Made a lot of progress (long) in reply to Don-Wi, 09-24-2007 08:48:04
The 12x32 silo.. do you have to unload that one by hand??? We had a old 12x24 and we could not find a unloader that went down to 12".
Don-Wi
09-24-2007 23:35:33
 Re: Made a lot of progress (long) in reply to PJBROWN VT, 09-24-2007 09:08:20
We've got an Armstrong in both silo's. Kinda hard to get them started some days, but they never fail.
Can even swap them out in just a minute too!
BLinWMi
09-24-2007 20:47:56
There are several models of silo unloaders that run in a 12 footer, even had one in an old 11 foot ribstone. The Patz 98A we have used in a 12 foot since it was put in in 78. I also had an old Clay in a 12 foot ribstone for a few years. I think Patz 98 models all go down to 12 foot, though the big drive wheels don't turn to well in a 12. I have a 98C in a 14 running haylage and it does fine.
super99
09-24-2007 01:39:23
Yep, you was busy. Good feeling to have it done and not have to worry about it anymore. Chris
Ebbsspeed
09-24-2007 09:22:21
 Re: Made a lot of progress (long) in reply to super99, 09-24-2007 01:39:23
OK, what's a "bagger"? I've been off the farm for about 25 years, just piddle with the old tractors now, so ain't familiar with current farming methods. Bagger used to be what we called some of the girls who God wasn't as kind to, but don't think that's what we're talking about here.
Don-Wi
09-24-2007 23:47:59
 Re: Made a lot of progress (long) in reply to Ebbsspeed, 09-24-2007 09:22:21
Like brad says, it's a machine that stuffs silage or haylage, or anything else the farmer wants, into a plastic tube. Bags come in different diameters and lengths, a different machine for each diameter.
Here's some pictures from the first time we rented it 2 years ago-
third party image third party image
It really helps keep the spoilage down, and it's much cheaper than putting up another silo and maintaining it.
The Bags are made out of a very stretchable plastic, and the ones that we get with the bagger when we rnet it have bars that you measure to see how good of a pack you're getting. And if they stretch too far or not enough you can adjust the preasure on the brakes, if so equipped with the net that holds the back of the bag with cables that run up to the machine on 2 big cable reels. The 10' bag, when filled, probably stretched to be almost 13' in diameter, if not more. We got a 150'er this year, and 2 years ago we got a 200' bag but still only filled about 150'- cost us around $200 or more for the 50 ft. we didn't use...
We put corn silage and haylage in it this season, we'll see how good the haylage digs out of it...
bradk
09-24-2007 11:20:05
Instead of blowing silage up in the silo,alot of people are bagging.Basically bagging is filling up continuous length of plastic material which kinda looks like large round bales under plastic tarps.Special machine is required.
