Tractor Talk Discussion Forum
How Does An LP Tractor Filter The Fuel?
in-too-deep
10-22-2007 12:53:12
I imagine L.P. gas is pretty clean, but do LP tractors have a filter? Do particulates just sink to the bottom of the tank? I'll admit I know very little about LP tractors, but I'm trying to change that. Thanks folks.
335LP
10-22-2007 19:06:37
 Re: How Does An LP Tractor Filter The Fuel? in reply to in-too-deep, 10-22-2007 12:53:12
Check out filters and combo filter fuel locks at propanecarbs.com I thought it was methyl mercaptan that made LP and natural gas stink but not sure what they make it out of ? Maybe dead Nebraska birds? Some regulator vaporizer units have a screen in them too but if just running on vapor most times you won't need a filter. The filters are usually a screen or several thin metal disks together and inside filter bowl after a while you will clean out lots of small black rubber like balls and nasty black stuff that settles out of it. Same nasty black oily stuff settles eventually to bottom of your tank too.
Hoss in Maine
10-22-2007 16:32:54
Thanks Allen,I always knew it were them small birds making that stink. Later Hoss
Allan In NE
10-22-2007 12:56:36
Yeah,
Most of 'em use a pressed brass filter not unlike those old Chevy "stone" filters of days gone by.
Catches most of the large rocks and small birds. Rest of the crap just sinks to the bottom of the tank. It's that "crud" that sets up the smell too.
Allan
jeffah20
10-22-2007 13:05:43
 Re: How Does An LP Tractor Filter The Fuel? in reply to Allan In NE, 10-22-2007 12:56:36
Small Birds?? - I do have a truck on LP and they do make a filter, buy it at your local LP place
Jon Hagen
10-22-2007 13:32:55
 Re: How Does An LP Tractor Filter The Fuel? in reply to jeffah20, 10-22-2007 13:05:43
Most have a little filter much like a small diesel fuel filter, be it foam, paper, ceramim, brass or string ball type. About the only difference is that the filter media and housing are made to take full tank pressure which can be as much as 200 psi.
