Tractor Talk Discussion Forum
diesel additives
rednekelmo
11-21-2007 19:17:11
does anyone know where to find antigel additives
in smaller sized bottled to dose maybe 10 gallons? and maybe some lube improver.my mom has diesel VW and I was trying to find something she could use without much trouble or mess.
Wardner
11-25-2007 12:56:33
 Re: diesel additives in reply to rednekelmo, 11-21-2007 19:17:11
I picked up 500 gallons of used but clean refrigerant oil (used in big chillers) for free from a Craigslist ad. It is similar to hydraulic oil but is formulated from a different stock. It will not wax up. I am running at about 10-20%.
I can't see any performance difference. I assume it is adding lubricity and will also lower the gel point. I'll bet that most HVAC contractors have to pay to have it hauled off.
If anybody thinks I am nuts, I like to hear from them.
guido
11-22-2007 18:03:08
Hey rednekelmo
Any auto store should have the additive.
If not certainly a truck stop, and the size that you need. Guido.
mike3320
11-22-2007 17:37:58
i just got a inline fuel heater for my truck. made by racor i think. says in the instructions will let u run with no additive at all.
Ray
11-22-2007 18:42:05
 Re: diesel additives in reply to mike3320, 11-22-2007 17:37:58
mike3320 What about the fuel brfore the heater,
in the tank and fuel line?
mike3320
11-23-2007 11:53:48
 Re: diesel additives in reply to Ray, 11-22-2007 18:42:05
these are mode more for big rigs. i havent hooked the thing up and tried it. if my truck has a return line ill be good. i guy i work with use to run fuel trucks for 20 yrs. he put one around his fuel filter. they make blankets to go aroud them. i dont think they would work on newer trucks??? on my truck the fuel seemed to gel going to the filter and then have problems in the filter. the newer fuel seems to gel at 0 degrees. i had kero and anti gel in it and still did it. so im going to try this. the guy i work with put this on his and never had a problem he ran just the anti gel in the tank with none cut fuel. the box says it will work with uncut fuel to forty below. i hope i dont find that out in pa but ill see how it works.
Ray
11-22-2007 17:04:36
Go to walmart or an tractor supply store,they sell it in quart or gallon containers.
markct
11-22-2007 10:00:48
i know what ya mean, its a pain to guess how much out of the quart bottles to splash in when ya only have put 20 gallons in a diesel pickup, what i did was take an old sta bil bottle which has the long neck and measuring part ya squirt it up into by squeezing, and carry that in the truck filled with fppf brand treatment works good and no mess
budn
11-22-2007 07:45:34
I would be careful about adding ATF fluid because of the color. Around here the DOT pulls samples of your diesel fuel and if its not clear you get big fines. On road fuel (road tax) is clear. Off road (none taxed) is pink or red.
Michael Soldan
11-21-2007 19:23:17
Ordinary gas line deicer or methyl hydrate works, you can mix a quart of automatic transmission fluid into some diesel fuel and add to the tank.ATF has an affinity for moisture and will remove it and lube the pump at the same time. Carquest has diesel fuel conditioner which cleans the injectors as well. The de icer will remove bacteria from the fuel that live only in the water in the fuel.
504-2
11-21-2007 21:00:28
 Re: diesel additives in reply to Michael Soldan, 11-21-2007 19:23:17
The cheapest that I have found is FPPF, I never had a freeze up in 10 yr of upper mid west running.
