Tractor Talk Discussion Forum
Need Schematics Electrical on LONG 610
Larry59
12-27-2007 05:32:50
I am in need of a print out of the wiring on a 610 Long DTC tractor. Mostly on the wiring of lights and fuse box area and to Key switch.
Larry59
12-27-2007 16:50:56
 KEH.. this is for you. in reply to Larry59, 12-27-2007 05:32:50
I posted under tractor photos here. Two pics of my 610 Long. Did you see them?
KEH
12-27-2007 17:51:57
 Re: KEH.. this is for you. in reply to Larry59, 12-27-2007 16:50:56
Larry,
Thanks for pics, however I can't get them to show up. Implement Photos under tractor Photos does show up, so I suspect there may be a web site problem. Will check back later. Glad you got the schematics from the manual. I need to look you up on the road map and see if i have been through that part of MO.
KEH
Larry59
12-27-2007 21:35:15
 Re: KEH.. this is for you.AGAIN in reply to KEH, 12-27-2007 17:51:57
Where abouts are you at? Should you ever need to call me. 573-378-2112 If on the computer it ties up the line till I am off it. Have caller ID and a tone that lets me know if others are calling in when on phone.
Have uploaded pic of tractor here.
KEH
12-27-2007 09:43:55
 Re: Need Schematics Electrical on LONG 610 in reply to Larry59, 12-27-2007 05:32:50
Should be in operators manual. If not, e mail me an address and I'll make a copy. Is the switch causing trouble? I had to put a new switch in and followed directions, but everything is not right. They list a Romanian switch and a Bosch switch. I need to work on the fuse box also.
KEH
Larry59
12-27-2007 16:34:23
 Found it KEH -Other info to you in reply to KEH, 12-27-2007 09:43:55
Thanks.. been a dog it would have bite me. lol Went in other room and picked up manual I got and thumb a bit. "Looked at it a minute and when " Shesssss ssssst" I seen a lot of wires under my tractor hanging down and tied together all cut. Since tractor is starting and running ok. I may just install a pull on light switch and forget that other. Did wire direct to fuse box on front lights with new wire. Got me some gratphite and put in key switch. Played with it a bunch of times and it started working correctly.
I seen on internet a new key switch was like 25.00 plus some shipping.
Want to figure out where I can get another key for mine. There a bit funny looking and the local dealer I got this from said he don't carry them. It's raining here and cold. Might get a bit of snow tonight and tomorrow they say." I am between Versailles Mo. and Gravois Mills Mo. off 5 hwy.
KEH
12-27-2007 18:14:00
 Re: Found it KEH -Other info to you in reply to Larry59, 12-27-2007 16:34:23
OK, got the pics to come up. Nice looking tractor, very nice if that's the original paint. Loader arm don't seem to have cracks and rewelds. A lot of people get a FEL and think it's a bulldozer, which it isn't, but that one looks taken care of.
I looked up Versailles on the road map, went on I 70 West to Kansas City and points West 30 plus years ago, so that's the closest I've been to there.
KEH
Larry59
12-27-2007 21:49:59
 Re: back again t KEH -Other info to you in reply to KEH, 12-27-2007 18:14:00
That was a long time ago. *S yes that is the original paint and has the decals on it. The loader says Long on it to.
The man that owned it before. Had a chicken farm and used it for that. Was advised that this is a medium loader and not for heavy work.
I have the tool box out of it and it is fixed. But want to paint it later. Also have the pto cover off and cleaned it up and sanded now. But not forsure on that color paint. Some called it Ford blue.. but it is not that dark.
That 4x4 works great. Have road that runs 45 degrees up hill. Tough in winter and sandy muddy in lots of rain. Gravel washes down and off it like running water each year. But this old tractor with rear blade took off a lot of that top mud and climbed that hill like it was ment for it. Two friends standing bye could not believe how it performed.
