Tractor Talk Discussion Forum
Intl. 444 diesel bleeding fuel system
Ryan Meade
01-21-2008 19:00:53
When bleeding injection pump (CAV), should you get same amount of fuel out of bottom and top vent plugs. Bottom is steady stream, top just enough to run down side of pump and slow drip.
I bled three times, tractor ran for 5 seconds and stopped. I have taken lines loose at injectors and cranked engine several times over the past few days, until battery dies.
I keep getting bubbles, only one line will squirt fuel when cracked.
georgeky
01-21-2008 23:35:12
 Re: Intl. 444 diesel bleeding fuel system in reply to Ryan Meade, 01-21-2008 19:00:53
Close the bottom, and just let it bleed from the top then try it. Did it quit to start with, or were you just changing filters.
Ryan Meade
01-22-2008 16:51:35
 Re: Intl. 444 diesel bleeding fuel system in reply to georgeky, 01-21-2008 23:35:12
Tractor was running fine before I changed filter.
No matter what I do with bottom bleed screw, top flow stays the same.
I know that I sucked alot of air into injector pump.
When tractor stopped I bled pump several more times,finally got alot of bubbles out of pump and flow was steady stream, from bottom screw, top never changed.
I have taken injector lines loose, have fuel coming out of all four lines.
None of them seems to be a very good strong stream.
JoshuaGA
01-21-2008 20:10:12
Know nothing about IH engines, but if you shut off bottom bleed, does it still drip down injector? Just a thought, Ma have air trapped between bottom and top screws. Shot in the Dark.
JoshuaGA
Ryan Meade
01-22-2008 16:55:57
 Re: Intl. 444 diesel bleeding fuel system in reply to JoshuaGA, 01-21-2008 20:10:12
No matter what I do with bottom bleed, top flow stays the same.
I even capped fuel tank and put air pressure to top of tank to help bleed system. Top bleed will barely increase, bottom bleed will shoot fuel out a foot.
