half way there
troyr
02-19-2008 09:23:38
finally able to post a picture of my 39 Allis B. We are just about to asemble it all back together, more pictures to come! thanks for all the help, without this forum I wouldn't have gotten this far. third party image[/img]
Janicholson
02-19-2008 13:37:16
 Re: half way there in reply to troyr, 02-19-2008 09:23:38
I love the tractor, I have owned a nice 38 WC. I also lost a principal of a highschool where I taught in ohio from using concrete blocks for holding weight. If what I see under the front is a solid block, you are probably OK if it has holes, do me a favor and spend 20 minutes changing to cribbing or a stand. I know it seems paranoid, but it is life and limb and they were not ment to take weight in that position. JimN
Nancy Howell
02-19-2008 12:49:30
Very, very nice. Even if its not green. A good job is a good job regardless of the color. When you get finished, be sure to post a before pic and an after pic.
mul-skiner
02-19-2008 12:57:59
 Re: half way there in reply to Nancy Howell, 02-19-2008 12:49:30
I know,I agree that orange is beautiful nice job!-M.S.
num hutz
02-19-2008 11:52:01
Is that orange just the primer for the final Green paint?just kidden!
troyr
02-19-2008 11:47:26
 Re: half way there in reply to El Toro, 02-19-2008 09:23:38
Your right.Matter of fact I got oil leaking out at that very spot this very minute.I have the gas tank and toolbox on now.I had made a gasket for that oil filter holder and I made a good one for that matter,I was going to make a thicker gasket,But now I think I'm going to take a razorblade and scrape off the paint.I'm also having trouble remembering how the Gov/throttle linkage goes back together.Thanks Troy. third party image
Gene Dotson
02-19-2008 13:13:14
 Re: half way there in reply to troyr, 02-19-2008 11:47:26
To stop the oil leak at the filter adapter, I dress the mating surface flat with a wide file or surface plate. The surface becomes warped from overtightening. A thick gasket worsens the warpage... Gene
Dick L
02-19-2008 12:08:22
One style Left side:
third party image
Another style left side:
third party image
Not sure I have a better picture of the right side. I will look some more.
third party image
Dick L
02-19-2008 12:16:56
 Re: half way there in reply to Dick L, 02-19-2008 12:08:22
Best I can do for now.
third party image
DickL
02-19-2008 11:04:17
Looks nice and I will look forward to more pictures.
A word of caution! If you do not have tape over where the oil filter housing bolts to the engine on where the magneto seals, you will need to remove the paint in those areas. The gasket will not seal on the paint and will seep oil.
notadeere
02-19-2008 09:51:34
 nice shine in reply to troyr, 02-19-2008 09:23:38
looks bright is that regular tractor paint or did u add hardner or clear ? just woundering as when i paint i use hardner in mine & its shineier & seems to hold up longer but it looks good so far & dont forget to post us the finishing pics
David Snipes
02-19-2008 09:38:41
Nice paint!
