Tractor Talk Discussion Forum
The mag and other stuff
Lanse
02-22-2008 17:34:39
I guess i can post now!! Yay!
I got the Mag today and havve no clue if it really works, and dont know what im doing. Old told me to cup my hand over the dohicky and spin it slowly.
It works.
How do i tell how good the spark is?? What should i know about handling it, mounting it on the tractor, and clenaing it up?? Theres some white stuff in the spark plug wire holes and i guess i'll unscrew that and knock it out. Where could i get the spark plug wires??
Your twin
02-22-2008 20:05:08
 Re: The mag and other stuff in reply to Lanse, 02-22-2008 17:34:39
Why couldn't you post?
Bendee
02-22-2008 18:42:40
If you must know how good the spark is,go through the same exercise but spin it FASTER.but I don't think I would bother,..take it as a given.
Mathias NY
02-22-2008 20:01:29
 Re: The mag and other stuff in reply to Bendee, 02-22-2008 18:42:40
If the impulse on the mag is working, spinning it faster won't make a difference. The impulse provides the snap you hear when you turn the mag over. It allows a spark to be created even at slow cranking speeds.
When I test a mag for spark, I clamp the base of the mag in a vise, connect a wire and spark plug to one of the ports on the cap, and spin the mag over with an adjustable wrench. I find the wrench keeps my hands from getting pinched.
Walt Davies
02-22-2008 18:03:56
Lance go to this site and download the book its not your mag but they all work the same an you can learn from how to clean and make them work.
Walt
old
02-22-2008 18:31:34
 Re: The mag and other stuff in reply to Walt Davies, 02-22-2008 18:03:56
Walt, he should have what he needs. When I sent him the mag I also sent him the complete manual for that mag by way of the net. But yes it never hurts to have as much info as you can get.
old
02-22-2008 17:58:09
Lanse the white stuff if from dirt dubbers. Just clean it out real well and is you have a small wire brush like in a gun cleaning kit use them to shine things up. If it did in fact zap you when you spun it over you probably are good to go since it had to jump a spark gap of more then 1/4 inch to zap you. As far as mounting look in the manual I sent you it will tell you more then I can on here
