Tractor Talk Discussion Forum
Kerosene in a diesel
BobReeves
02-25-2008 11:52:00
Can you run kerosene in a diesel? Have 10 callons of kerosene I have no use for and was wondering if I could put it in my tractor.
trucker40
02-26-2008 10:04:20
 Re: Kerosene in a diesel in reply to BobReeves, 02-25-2008 11:52:00
Yes but it lasts about 1/2 as long,Thats how it was in over the road trucks anyway.Where it gets real cold you have to have it mixed with diesel to even get it to run.
Roy in georgia
02-25-2008 18:02:32
seems as tho you have your answer but when I pulled my truck up to the diesel pump didn't realize they had kero on the other side put 8 gal in a 13 gal tank finished it with diesel and ran it all out only took 1 1/2 trips to work and it was gone as usual
Leland
02-25-2008 16:43:09
I drove a delivery route each night for a while and I had a 4900 IH with a 466 and if pushing bad winds I would stop along the route and pull up to the kerosene pump and put in 20 gallons or so to get me to my fuel stop .it will give you less power since it's thinner and the engine will also burn a little more fuel bacause of this also
jdemaris
02-25-2008 16:00:55
#1 diesel IS a mix of #2 diesel and kerosene - it's been used since compression-ignition engines were invented and had to be run in cold climates.
BobReeves
02-25-2008 14:09:52
Thanks Gang, looks like I've found a use thanks to you guys...
ChrisB
02-25-2008 12:43:11
Opps
Forgot to mention that JP-8 does have a lubrication additive.
ChrisB
02-25-2008 12:42:15
Military got rid of diesel back in the 90s and now runs all diesel vehicles on JP-8 which is more kerosene then diesel.
Bill46
02-25-2008 12:42:53
If it were mine...I would pour about a quart of 30W for every 5 gallons.
Just my 2 cents...the injector pump needs the lubrication.
Michael Soldan
02-25-2008 13:39:40
 Re: Kerosene in a diesel in reply to Bill46, 02-25-2008 12:42:53
Bill46, I agree, that's exactly what I would do..lubes the pump, give a little more energy to the fuel and it sure as heck won't hurt anything! A friend had 25 gallons of stove oil..I used it in my tractors with oil added, it worked well!
Bill46
02-25-2008 13:51:08
 Re: Kerosene in a diesel in reply to Michael Soldan, 02-25-2008 13:39:40
Seems I remember back in the 50s dad ran out of diesel picking corn and all we had was stove kerosene. He put I think about a quart of oil in each 5 gallon of kerosene...got the corn crop in.
KIP in MX
02-25-2008 12:34:56
I ran a Toyota Landcruiser with 4 cyl diesel engine on Jet A for 35000 km and never had any problems. It did have a little less power than running it with diesel.
El Toro
02-25-2008 14:25:50
 Re: Kerosene in a diesel in reply to KIP in MX, 02-25-2008 12:34:56
One of my neighbor's was in the Air Force and had one of those stubby trucks for pulling mobile homes and he filled the big gas tank with 140 octane aviation at one of those AF bases in Florida. He said he had to stop and add a little regular once in a while when he was coming to MD.
Hal
gahorN
02-25-2008 12:02:53
Jet Fuel IS KEROSENE! Doh.
Tramway Guy
02-25-2008 12:02:07
I have run more than 50% in really cold weather, no problems. 10 or 20 % is no big deal.
The only downside is that there is not as much energy in Kerosene as there is in Diesel Fuel.
Deisels can run on anything from Vegetable oil to Jet Fuel with no real modifications.
But if you have Roosa Master or Bosch distributor-type pumps, lubrication can be an issue. So keep the proportion of kerosene reasonable.
El Toro
02-25-2008 11:56:31
I would mix it with diesel fuel. I had 5 gallons of kerosene and I'm adding one gallon everytime I fuel up the car. Runs good too. Hal
flying belgian
02-25-2008 11:55:07
yes. When I had a fleet of trucks I always ran up to ten percent kero depending how cold.
