Tractor Talk Discussion Forum
Mounting a PTO Hydraulic Pump
Joel Rutkowski
03-12-2008 18:08:25
This may be a silly question but how is a PTO Hydraulic pump usually mounted? Do people make there own brackets? To what should it be bolted?
Also, I have a 55' Ford 850, would 21 GPM pump be too much?
thanks, joel-
mj
03-13-2008 08:32:10
 Re: Mounting a PTO Hydraulic Pump in reply to Confusion, 03-12-2008 18:08:25
gene bender said: (quoted from post at 01:38:25 03/13/08) Since the pump goes over the pto a good strong chain will do. Now the 21 gmp doesent say how much PSI AT 540. Should be a bunch.
The specs for the 'Prince' HC-PTO-1A are - 21 GPM @ 540 RPM giving 2000 PSI and requiring 32.1 HP. 8)
gene bender
03-13-2008 00:38:25
 Re: Mounting a PTO Hydraulic Pump in reply to Joel Rutkowski, 03-12-2008 18:08:25
Walt davies
03-12-2008 22:59:00
On my Case LA my Char-Lynn bolts to where the PTO shield was bolted to.
Walt
third party image
third party image
JMS/.MN
03-12-2008 21:28:31
Just to reinforce what the others say- you mount it loose! Simple angle bracket and chain to hold it in place and let it wiggle. Anytime you mount a pump solid- it better be aligned darn near perfect- then the lovejoy or chain couplers eventually wear out. Hydraulic or sprayer pumps on a pto shaft just float like in the picture. The pump will wear out before the mount.
Steven f/AZ
03-12-2008 18:33:09
21 GPM is good for a loader, depending on the size of the cylinders... if you have a smaller loader with smaller cylinders it might go pretty fast.
To mount, bolt an angle iron to the side to hit the drawbar and slide it on the PTO shaft. Loop a chain around so it can't slide off.
third party image
supera3
03-12-2008 18:17:24
Mine mounts with a chain to the drawbar, some pto shafts are not perfect. The chain allows a little "give" if you will. Gary
old
03-12-2008 18:17:20
Need more info to help you much. They make a good number of different mounts for them plus you need to say what your going to be doing with it to tell you if thats to many GPM or not enough. For a loader its to much but for a log splitter about right. Plus a Ford 850 does not have live PTO so for some stuff that is a problem
buickanddeere
03-12-2008 18:12:16
Any place to mount a crankshaft driven unit? Is the pto live?
Joel Rutkowski
03-12-2008 18:35:19
 Re: Mounting a PTO Hydraulic Pump in reply to buickanddeere, 03-12-2008 18:12:16
No live PTO, but I'm going to use it for a log splitter, 4" cylinder.
I was considering a prince pto pump, see link. Not sure how I would attach it to the tractor. I'm sure I could fabricate some sort of bracket but thought maybe that was making it harder that it needed to be?
