Tractor Talk Discussion Forum
Need A Plow?
Allan In NE
03-19-2008 12:28:22
Neighbor down the road is selling his plow. Just thought I'd ask. :>)
Allan
third party image
Dan-IA
03-20-2008 10:18:59
 Re: Need A Plow? in reply to Allan In NE, 03-19-2008 12:28:22
'round here, that's worth scrap prices. I don't think they allow us to plow anymore with the conservation plans - especially after the watershed stuff a couple years ago.
For that matter, I have never understood how the plow bottoms in the air would ever touch soil, they look like they're bolted solid to me. But I'm a new kid.
Lee in Iowa
03-19-2008 20:03:33
A little big for me, but if you see something with 4 or 5 bottoms on each side and a little more red in color let me know.
thanks, Lee
Lee in Iowa
03-19-2008 20:02:22
thanks, Lee
Dairy Farmer in WI
03-19-2008 18:39:57
oofda! heavy! sure looks like it might make shorter work of plowing though!
DF in WI
Steven f/AZ
03-19-2008 17:01:50
That would look kinda good behind this:
third party image
But, for the few acres that we actually need to plow I think Dad will just rent an offset disc.
Mike (WA)
03-19-2008 15:59:09
Rollover (two way) plows got their start in "rill" or "flood" irrigated areas. Don't know if any of you in the midwest are familiar with this, but in the Columbia Basin of eastern Washington, irrigation is from canals that follow the contour of the land, and with small pipes called "siphons", you drew water out of the canal and sent it downslope in the fields- either just over the field ("flood") or into grooves put into the field for rowcrops ("rills"). When you've got water trying to find its way downslope, a dead furrow isn't just an inconvenience, its a deal-breaker. Hence, the two way plow. Guys soon found out that even if you didn't have the irrigation imperative, it was just plain easier to start at one side of the field, and work across it, rather than laying out "lands" and such. I like the look of the plow in the picture, but would have to do some research to determine whether my Farmall C would pull it. LOL.
IHC Red
03-19-2008 17:34:22
 Re: Need A Plow? in reply to Mike (WA), 03-19-2008 15:59:09
Keep your eye on the heat gauge.
Pitalplace
03-19-2008 15:20:23
You should bring that down to our plow day south of North Platte the first Saturday of April. It wouldn't take long and we would have to do something else :P
Allan In NE
03-19-2008 15:48:23
 Re: Need A Plow? in reply to Pitalplace, 03-19-2008 15:20:23
I have nothing that will lift it, nothing that will haul it and I fer darned sure don't have anything that will pull it. :>)
Allan
TGIN
03-19-2008 14:05:26
How Much cash will it take to pull it out the driveway ??
Allan In NE
03-19-2008 15:46:22
 Re: Need A Plow? in reply to TGIN, 03-19-2008 14:05:26
Oh,
I have no idea. I saw he had it advertised when I was in at the bank.
Allan
135 Fan
03-19-2008 18:11:18
 Re: Need A Plow? in reply to Allan In NE, 03-19-2008 15:46:22
Pretty smart neighbor if you ask me. Advertises his plow while you're counting your millions at the bank. LoL Next week he'll have a Farmall ready to advertise that will pull the plow. Dave
J Schwiebert
03-19-2008 13:52:10
How common are roll over plows out there? We used to sell an average of 1-2 a year here in northwest Ohio. They were all 3 or 4 bottom and I guess 1 2 bottom. Not that big but one farmer did have a Towner behind a 5020 with a 318 Detroit under the hood?
Allan In NE
03-19-2008 14:09:50
 Re: Need A Plow? in reply to J Schwiebert, 03-19-2008 13:52:10
Lots and lots of dry beans raised out here because it is hot, dry and they do well on irrigated land.
Kinda like they do out in Idaho. Dry beans are normally rotated behind corn and require a clean seedbed for the cutters.
So, yeah. They are all over the place out in this area.
If any of you guys are coming out this way to that big junkyard auction, you'll probably see 'em running all over the place down in that valley.
Allan
Billy NY
03-19-2008 13:10:37
I remember you explaining what those are built for, and I still forget exactly how it works when you get to the end of the furrough to turn and change directions, never saw anyone with one in the fields around here. Double the wear parts to replace, but they probably last 2x as long rotating sides like that.
mkirsch
03-19-2008 14:05:12
 Re: Need A Plow? in reply to Billy NY, 03-19-2008 13:10:37
Same here. They seem much more common out West.
I would think that a 2-way or rollover plow would be handy in the smaller fields we have here in Upstate NY, but nope, all you see are conventional semi-mounts on smaller farms, and trailer plows behind the big 4x4s.
Maybe it's just the opposite of what I'm thinking? Maybe they're better in the really big fields because you can start at one side and work your way across, rather than splitting the field up into sections and having multiple crooked dead furrows... I can see where if you don't get the sections straight on a 40-acre field, life will be miserable. It's bad enough on a 12-acre field... All the running around finishing up little triangles on each end.
Don L C
03-19-2008 18:36:23
 Re: Need A Plow? in reply to mkirsch, 03-19-2008 14:05:12
When my Dad was young.....back in the early 30s we had pictures of horse drawen plows that plowed that way.....could plow around a hillside doing strip farming....Don
Billy NY
03-19-2008 14:35:18
I thought the same thing about them being used here, I was out in the local ag areas yesterday, went up to put a set of points and tune up a JD2020 for a friends father, and saw that the big dairy operation in town has gone back to planting fields in the vicinity that don't even look big enough to turn around in, surrounded by hedge rows, just a lot of small broken chunks of land, most all of it in corn. Years back, everything was in crops or hay grasses except the front lawn !
Allan In NE
03-19-2008 14:20:30
Spinners are used because they are efficient; no jackin' around on the ends. I’d just about guess that a spinner will cover an easy 1/3 more ground in a day.
They'll plow good and deep to insure all trash is covered and they’ll do it while leaving the land as level as a pool table.
Allan
Rick in IA.
03-19-2008 13:08:00
Wow !
How big of tractor would it take to pull it ?
Rick
John51
03-19-2008 12:43:05
Thought maybe you'd mount that on your M with the new hitch you put on it.
Allan In NE
03-19-2008 13:01:36
 Re: Need A Plow? in reply to John51, 03-19-2008 12:43:05
The old M probably couldn't even lift the center link for that brute. :>)
Allan
PhilcaseinWPA
03-19-2008 14:54:52
 Re: Need A Plow? in reply to Allan In NE, 03-19-2008 13:01:36
knock about 4 of those bottoms off and deliver it and I'll take it..... if the price is right.
Phil
RobMD
03-19-2008 16:54:47
 Re: Need A Plow? in reply to PhilcaseinWPA, 03-19-2008 14:54:52
Then you would have problems keeping the tractor from plowing in circles, it'd set the plow off to the far right!
