Tractor Talk Discussion Forum
Hydralic pressure
larry bledsoe
03-19-2008 17:03:48
My 1978 yanmar 330D (total 1500 hours) has a lazy lift capabilty. Stick the bucket into a pile of gravel and it's lazy about lifting it. A friend says the system needs increased pressure, to turn the screw on top of the spring a 1/4 turn at the hyd control and see if that helps. Well the cover is like very smooth surface, not hex headed and no way to get at the screw adjustment. Like it's preset for tension/pressure. any ideas??
DiyDave
03-20-2008 14:18:45
 Re: Hydralic pressure in reply to larry bledsoe, 03-19-2008 17:03:48
Best thing to do is to hook it up to a flowmeter, after making sure that the relief valve is OK. You will also need to have the original specs for comparison.
larry bledsoe
03-21-2008 07:49:00
 Re: Hydralic pressure in reply to DiyDave, 03-20-2008 14:18:45
Thanks for your help.
buickanddeere
03-20-2008 12:58:40
 Re: Hydraulic pressure in reply to larry bledsoe, 03-19-2008 17:03:48
Hydraulic
How good of an idea is it to increase the pressure without knowing the exisiting system pressure and the pressure after adjustment? Breaking a loader frame, blowing a hose or ram seal is going to drop the load onto something valuable or a person. Odds are those hoses are 30 years old and are about ready to fail under normal working pressure. Making the tractor unstable with too much weight over the front and not enough on the back is dangerous as well. Gravel is very heavy, odds are 1/3 to 1/2 bucket is lots.
larry bledsoe
03-21-2008 07:48:02
 Re: Hydraulic pressure in reply to buickanddeere, 03-20-2008 12:58:40
Thanks for the heads up, I'll keep that in mind.
greygoat
03-20-2008 07:18:58
Pressure equals lifting power.
GPM, Gallons per minute, volume, equals lift speed
larry bledsoe
03-21-2008 07:47:00
 Re: Hydralic pressure in reply to greygoat, 03-20-2008 07:18:58
Thanks, I'll keep in mind.
greygoat
03-20-2008 07:18:38
greygoat
03-20-2008 07:18:16
soundguy
03-20-2008 06:14:23
stick a pressure gauge onto one of the laoder feed lines and deadhead it.. see what pressure you are making.
Have you cleaned the hyd fluid strainer?
soundguy
larry bledsoe
03-21-2008 07:58:07
 Re: Hydralic pressure in reply to soundguy, 03-20-2008 06:14:23
Actually twice. The system designed where trans fluid and Hyd fluid are common. The on board mesh screen is located at the bottom of trans mission. Dirt cleaned off, fluid changed in previous sessions. Empty bucket works great but when loaded, sluggish. Must be Flow rate. The guy who suggested the control adjustment, started selling these and Kubotas in the mid seventies. I'll go back to him. thanks,
msb
03-19-2008 19:02:43
Could be a restriction in a hose.
J Schwiebert
03-19-2008 17:56:02
By lazy if you mean slow increasing the pressure will not help. Flow (gallons per minutes) determines how fast the bucket will move. Also remember a leaking relief acts just like a worn out pump.
larry bledsoe
03-21-2008 08:01:51
 Re: Hydralic pressure in reply to J Schwiebert, 03-19-2008 17:56:02
Like there is pump, hoses, control valve, levers, and hyd cylinders. where would the releif valve be in that circuit?
thanks,
