Tractor Talk Discussion Forum
What loader is the best one for 400 Inernational tractor?
Brian from Kans
03-29-2008 20:23:17
I have a 400 International tractor with a trip-bucket loader and I am interested in finding out which is the best loader to fit my tractor. I have dual hydraulics on it. So if someone has some information to help, I gladly appreciate it. thanks
Brian from Kansas
03-30-2008 10:35:48
 Re: What loader is the best one for 400 Inernational tra... in reply to Brian from Kansas, 03-29-2008 20:23:17
Thanks to all who answered my question. I got some great ideas from you guys. much appreciated.
Brian from Kansas
03-30-2008 10:35:41
J.C.in AZ.
03-30-2008 08:53:19
Given a choice a Farmhand would be the Loader of preference.
Steven f/AZ
03-30-2008 07:10:04
 Re: What loader is the best one for 400 Inernational tractor in reply to Brian from Kansas, 03-29-2008 20:23:17
The F11 is my favorite loader for that size tractor, Dad had his F11 on an M, 460, 560, 400, and finally a 656 hydro.
Allan In NE
03-30-2008 07:21:51
 Re: What loader is the best one for 400 Inernational tractor in reply to Steven f/AZ, 03-30-2008 07:10:04
And,
Didn't change a thing as far as the mounts go. :>)
Allan
third party image
Allan In NE
03-30-2008 06:35:21
I agree, you have an excellent loader tractor if it is equipped with a wide front.
Like someone else said, since you have a live PTO, use a PTO pump and get away from the tractor's hydraulics.
Woods/DuAl 250, Koyker K5(?), Westendorf TA-26, Farmhand F-11 all would make you a good loader.
The key is in the mounts.
Allan
Armand Tatro
03-30-2008 04:35:03
What kind of loader do you have? Should not be too hard to add a bucket cylinder. I have done it. Armand
Brian from Kansas
03-30-2008 10:29:14
 Re: What loader is the best one for 400 Inernational tra... in reply to Armand Tatro, 03-30-2008 04:35:03
Thanks for your answer on my loader question for the 400 International. How did you go about putting a cylinder on. I buy cylinders at auction? Thanks, Brian
Brian from Kansas
03-30-2008 10:29:10
Brian from Kansas
03-30-2008 10:28:59
Bruce Hopf
03-29-2008 21:05:30
I have a Fordson Dexta, with a Freeman Loader. I bought the tractor and loader seprate 8 years ago. The loader I bought from another farmer, that was upstairs in his barn for over 20 years. The loader was equiped with a trip bucket as well. I revoved all the trip bucket parts. I Put a 14" by 2 1/2 hydraulic cylinder mounted in the middle under the top cross member, and removed the lower cross member. I ran two hydraulic lines the length of the right loader arm. Installed a two spool valve, on the rear of the right loader bracket, with 2 quick couplers for the bucket. One side single acting spool to run the loader, and the other side a dual acting spool to run the bucket. I then ran 2 hydraulis lines from the valve to the back of the tractor. I also put quick couplers on the loader cylinders, to dicconnect the hydraulic lines, so when I remove the loader, I can leave the loader cylinders on the loader. I built 2 hangers out of flat steel, to hang them up where the loader attatches to the loader mounts. Built a quicktatch plate, to change buckets. Have a 5' material bucket, 4' tine bucket for solid manure, and a forklift bucket for skids.
Cheaper to do it this way then to buy a whole diffrent loader. I went and looked at a few used loaders for $700.00 to $1000.00 Fixed mine up this way for under $700.00. Only thing I don't have is down preasure. I don't have any problems digging in the ground with it. Just have to tip your bucket back a foot or two where you want to dig, and rool your bucket back as you drive ahead.
Hope this helps.
Bruce
Scott in SF
03-29-2008 20:33:00
Don't know if they are the best but many 400 IHC's were fitted with Farmhand F 10 and F 11s with a pto pumb. We have 2 Farmall M with one of each. To say they gave excellent service is an understatement. I can't even imagine how many acres they have hayed, cows they have fed, lightbulbs changed, manure loaded, motors pulled ect.
Brian from Kansas
03-30-2008 10:33:15
 Re: What loader is the best one for 400 Inernational tra... in reply to Scott in SF, 03-29-2008 20:33:00
Thanks for the help on my question.
