Tractor Talk Discussion Forum
Ford 1710 starting problem
John Houck
04-15-2008 10:10:32
I have a Ford 1710 that broke a fuel line and all the diesel drained out. Now it won't start. It turns over fast but won't fire. Do I need to bleed the injectors and if so, how do I do this.
Any suggestions would be greatly appreciated.
TomTex
04-16-2008 05:15:07
 Re: Ford 1710 starting problem in reply to John Houck, 04-15-2008 10:10:32
Bleeding it correctly is very specific to model. Follow instructions in your Operator Manual step by step. Tom
Mike M
04-15-2008 11:12:15
You should have bleed screws at the filter and injection pump bleed the air there first, then you also may need to loosen the lines at each injector and crank until fuel comes out.
