Tractor Talk Discussion Forum
The plan did not come together.
IaGary
05-15-2008 16:24:18
Sprayed one field after noon today and cut a few tracks so I quit. It has to dry some more before planting or tilling.
Cloudy most of the day so it did not dry much.
Gary
kyplowboy
05-15-2008 19:59:47
 Re: The plan did not come together. in reply to IaGary, 05-15-2008 16:24:18
I hear ya man. They are say'n that 50% of my county's corn is planted but I don't see how. I only have 16 acres to plant, 10 acres of it has been good a few times and I have gotten over it two times with a disk, the other 6 acres dried out one time to get across it on time real kight like. They are give'n us rain every other day for the next week. I have tobacco plants that are going to be running away before long and realy need several more passes over that ground.
I am find'n seaps in places I never seen'm before.
Been a wild spring.
Dave
Cliff Neubauer
05-15-2008 18:02:57
third party image
We were hoping to start spraying today too but it was cloudy most of the day and more moisture came up last night than dried off today. We've been so wet that the wet spots are really wet and even with tracks on the sprayer tractor it will leave tracks in waterways and terrace channels.
IaGary
05-15-2008 18:58:48
 Re: The plan did not come together. in reply to Cliff Neubauer, 05-15-2008 18:02:57
Cliff does that rig turn alright on the ends without gouging the ground like a steel track Cat does?
I realize you don't turn very short with those wide booms but if you did would it tear out planted corn as it slides around?
Also how does it act in wetspots when one track is in the dry. Will it throw you in the wet spot?
Gary
Cliff Neubauer
05-16-2008 08:53:29
 Re: The plan did not come together. in reply to IaGary, 05-15-2008 18:58:48
third party image
Here is a picture I took spraying wheat several weeks ago that shows what happens when you turn, this was extremely wet ground and it still didn't do too much damage but you wouldn't want to drive it around in your yard. Under a heavy pull wet spots can be a problem but I got through one mud hole I'm pretty sure an MFD wouldn't have made it out of.
Lanse
05-15-2008 16:44:00
13 of the last 15 days have had rain here. The weeds in the unplanted parts of the garden and field are incredible. Its supposed to hold up this weekend, sunday night in dragging that if it takes 4WD, differential lock, and the loader. Im not loosing this for the second year in a row.
rednekelmo
05-16-2008 05:11:54
 Re: The plan did not come together. in reply to Lanse, 05-15-2008 16:44:00
not after the rain you got last night, you'll need pontoons and an outboard to work the garden
Eric in IL
05-15-2008 16:36:26
Gary,
Count your blessings,it started raining here at 9:00 this morning (50 miles south of Spfld. Il) and is just now letting up. Haven't checked the guage yet but I'm guessing seven tenths. We need four days of sun and wind before thinking about field work again. I had a fire in the shop stove today and didn't break a sweat.
How is that new planter treating you?
IaGary
05-15-2008 17:04:06
 Re: The plan did not come together. in reply to Eric in IL, 05-15-2008 16:36:26
third party image
The monitor says it is doing everything right.
We will see when it comes up I guess.
I had a couple of bugs the dealer and I had to work out, otherwise OK
billonthefarm
05-15-2008 19:35:07
 Re: The plan did not come together. in reply to IaGary, 05-15-2008 17:04:06
I never noticed in your pics, is that a vac planter? I see it says you are going about 6 mph. Most guys around here with the fingers stay 5 or less. I run a steady 5 with a deere vac. As far as population we havent planted corn under 30,000 for 15 years. This year for the first time I planted one variety at just over 40,000. More population has turned into more bushels at harvest and so far no stand issues. I'm keeping my fingers crossed on that 120 acres planted at 40,000! bill
Dan-IA
05-15-2008 20:25:06
 Re: The plan did not come together. in reply to billonthefarm, 05-15-2008 19:35:07
hey bill, what do you do for fertilizer? I'm in Iowa too, and I only plant around 28000 because when we accidentally planted 33000 a couple years ago we got cocktail-weiner sized cobs with mold growing on the ears. What's your secret?
Eric in IL
05-15-2008 19:21:01
That is a slick looking monitor. I wouldn't be surprised if it could tell you what you ate for breakfast.
Can you shut off individual row units from the cab?
IaGary
05-16-2008 04:18:54
 Re: The plan did not come together. in reply to Eric in IL, 05-15-2008 19:21:01
Yes you can shut off a row if it acts up or for whatever reason.
When I was in 36 inch rows about 29,000 is all I ever planted for stand ability reasons. 30 inch rows spread the seeds out a little so I am trying 30,000.
It is a finger pickup planter, not vacuum.
I usually stay around 5.5 mph as that is what the book recommends.
JoeBob/IN
05-15-2008 18:44:22
WOW! Nearly 30k for a population. You guys are spoiled with your soil out there. No wonder Iowa is the king of corn. Don't think I would attempt that on our sand here even if it had a pivot.
bradk
05-15-2008 20:05:27
 Re: The plan did not come together. in reply to JoeBob/IN, 05-15-2008 18:44:22
Heck we plant 32,000 in 30"rows in SE Minn and we're considered low to the big farmers.They plant close to 38,000 pop.We had 216 bu.average corn last fall
KEH
05-15-2008 16:32:23
1/10 inch rain here. Enough to keep me from cutting oat hay, not enough to do much good. Oh, that dry area in S GA I mentioned in an earlier post? It got rain but it was spotty. Still generally dry.
Here in SC we ar 4 in. behind for year.
KEH
