Tractor Talk Discussion Forum
Toro ZMaster Question
Tom B...IN
05-15-2008 16:35:55
I need the advice of ya'll again..
Ive got a toro zmaster (commercial ztr) that has an 18 horse kohler on it (105 hrs). This spring when I was servicing it I was going to check the plug. The plug wire is very hard to grab at the end (if you have ever worked on one of these you will know what i mean) and i ended up yankin the metal part that goes on the plug off the wire. Asked a few friends if I could just re-crimp it on there and they said it would work. Now when I go to "cold start" it is very hard to start. It spudders and spudders and finally will run. Each time I go to mow it seems to get harder and harder to start, but once its running i dont have any problems.
I am wondering if #1- my crimp job is not good enough and i need a new coil/plugwire #2 the gap I set the coil has changed or was wrong to begin with?
#3 it something different.
Would really appreciate any thoughts or advice.
Thanks as always
Tom
Rick Kr
05-15-2008 19:19:14
 Re: Toro ZMaster Question in reply to Tom B...IN, 05-15-2008 16:35:55
third party image
Tom,
Myself and friends have built many spark plug wire sets. You should use a new end.
The crimp tool does the best job, but we have repaired many at the track with needle nose pliers or the cheap bullet style crimpers.
The ones in the picture are 11mm wires and have been going for 6 years no problems. Crimp, add a little silicone spray to the boot and your done.
Rick
Don L C
05-16-2008 08:45:06
 Re: Toro ZMaster Question in reply to Rick Kr, 05-15-2008 19:19:14
Hay Rick ---
Nice looking rod,I would like to see more....
Iam 72 yr. old and disabled.....I started to build a thirty two (dont have the body)but many new pieces..... Air ride in rear;18 1/4"wide rear tires and alum. wheels;large disc breaks (pro street);plated hot rod headers;2"x4' steel frame with 9" narowed Ford rear end, 3.50 gear...tons of other new parts;5L Ford engine and auto. trans.
Anybody interested will sell at 1/2 the investment..e-mail open ----- ---Don
Rick Kr
05-16-2008 10:47:30
 Re: Toro ZMaster Question in reply to Don L C, 05-16-2008 08:45:06
Don,
Put it on ebay. Never seems to be a lack of people wanting to pay too much for something. Ebay is great for selling, but I rarely buy anything.
Rick
JT
05-15-2008 16:54:28
Tom,
You cannot buy a new "plug wire", it part of the coil assembly.
If you had coil off, the air gap should be .012 on a Kohler Command.
You cannot "recrimp" a plug wire, go buy a new spark plug wire end.
Jim
JoeBob/IN
05-15-2008 18:40:47
 Re: Toro ZMaster Question in reply to JT, 05-15-2008 16:54:28
You can recrimp plug wires. Done it many times for the same reason... pulled off the end but the tab stayed on the plug. They used to sell sets that you had to cut and crimp the ends on. So as long as you do it correctly you can recrimp them.
Lanse
05-15-2008 16:46:28
gap on my single cylender briggs is .07 to .09, i dont know if that helps
