Tractor Talk Discussion Forum
Farmall 504
german viking
05-20-2008 11:21:03
Just had the carb rebuilt and can only keep the tractor running with about full choke. Also cannot throttle up unless choked. Tried the adjustment screw from full in to three turns out. Any ideas?
504-2
05-20-2008 18:35:06
 Re: Farmall 504 in reply to german viking, 05-20-2008 11:21:03
Blow air back through the fuel line from the carb to the tank(betting the tank has gunk in it)if it runs then you know too clean the tank.
ohiojim
05-20-2008 15:56:29
had same problem with my farmall bn,.. float needed to be adjusted....
Gerry....WI
05-20-2008 14:33:48
How is the gasket between the carb and manifold?
Also between the manifold and the head.
Mike (WA)
05-20-2008 12:57:59
You're not getting enough fuel. Filter probably clogged- there should also be a filter at the inlet of the carburetor, as well as the sediment bulb.
german viking
05-20-2008 13:16:20
 Re: Farmall 504 in reply to Mike (WA), 05-20-2008 12:57:59
have good fuel flow any other ideas?
El Toro
05-20-2008 14:27:14
 Re: Farmall 504 in reply to german viking, 05-20-2008 13:16:20
Remove the the main adjustment screw from the bottom of the carburetor and see if there's a good flow of gas from the carburetor. There may may be a screen behind the tube fitting where your gas line is connected that's full of crud.
Did you open this main adjustment screw? This is
where you can enrich the fuel mixture. Hal
