Tractor Talk Discussion Forum
Electrolysis on plows
garytomaszewski
05-23-2008 10:28:39
I just got a 3 bottom Little Genius with slatted moldboards,it is a pain to try to wire brush them without catching the wheel. Will they scour well if i use electolysis. Where can I find parts, these are the 4 piece bottoms (share, point, shin, moldboard [Plow Chief ?]) Some of the slats are worn and one point is welded.
Bruce Hopf
05-23-2008 18:56:15
 Re: Electrolysis on plows in reply to garytomaszewski, 05-23-2008 10:28:39
I used a sand blaster on my plow to clean most of the rust off it. Then I did a little plowing, that polished everything up nice. You can get a small hand held, gravity feed sandblaster real cheep. The trick to them is keep your air dry, otherwise it will plug up your nozzles. Use 2 hoses, with an air dryer in between.
Hope this helps.
Bruce.
