Re: W6 Charging System Troubleshooting
Posted by Roger Mills on February 24, 2007 at 05:07:16 from (71.213.68.215):
In Reply to: W6 Charging System Troubleshooting posted by chadd on February 23, 2007 at 22:07:51:
Since the ground on the gen F caused it to charge the gen should be OK. Also the cutout relay in the reg closed when you gave it the gas so that at least worked, (might not be set quite right but that can come later). Either there is a wire from the gen F to the reg F and if so it uses a resistor inside to ground, or the wire from the gen F goes to the light switch and if so the light switch may have a bad ground or a bad resistor. If this wire is there then the reg F has no wire on it. You can check this next by disconnecting the wire from the gen F and adding a jumper from the gen F to the reg F and it should charge at about 10 amps. I had this bad ground problem and added a wire from the switch case to the tractor frame. The light/gen switch connects a resistor between the gen F and ground when you turn it on and may switch the gen F direct to ground if it has a separate detent for the headlights and some use two detents for low and high briteness. It should charge at 4-5 amps when on and 8-10 amps if in the headlight detents.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
