An Alternative View
Posted by A. Bohemian on April 24, 2007 at 06:49:48 from (207.170.88.163):
In Reply to: Re: Farmall A Series Cylinder Compression Ratings posted by dunniteowl on April 23, 2007 at 20:12:48:
(Hal and Jim, don"t be afraid to contradict me. I will defer to your more extensive experience.) Dunnite, isn"t this the tractor that was spitting oil out the stack after you perhaps poured transmission fluid into the oil by mistake? Yes, this tractor will run with those readings. Someone (I forget whom) is fond of pointing out that they had a flat-head Ford V-8 that was winning races with 40 lbs. in each cylinder! But, in that famous instance, the compression was low but the differnce between cylinders was not great. I did the math, and came up with a seventeen percent difference between the highest and the lowest compression readings. That may be only marginally acceptable. The "wet" readings may be somewhat better. Compression testers are not completely accurate. And, a compression test itself is not the final authority. Nevertheless, it is my personal belief that if the gasket is now correctly installed, the valve train is functioning correctly, the plugs are all seated correctly, etc., and these are accurate readings, you are headed for a rebuild sooner or later. Also, you"ve named this tractor, which leads me to believe you are fond of it. If you don"t already know, delaying a rebuild by continuing to run a worn engine can lead to more extensive and expensive damage. Finally, there is a frustration factor. Again, the tractor will run with those readings. It may be quite hard to start, though. And, will it pull well enough to run a mower? You won"t know until you get it running and try; and my personal belief is that it will only pull well enough to cut thick or high grass if you make half a swath on each passage and stay in first or second gear. Very frustrating. If the cash is available, consider plunking it down for a rebuild now. If not, start saving. Hal? Jim?
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
