SC Hydraulics Problem - Long
Posted by Skycarp on May 17, 2007 at 18:08:05 from (206.81.147.17):
I hope someone here can help me with my hydraulics problem so I won’t have to go at it blind. I am restoring an SC, with fast hitch. I am new to Farmalls and their hydraulic systems. I have the IH-8 manual and the Blue Ribbon service manual for the touch control. I have read the Troubleshooting Test Procedure but do not have a test valve to check pressures so I do not know if I can follow these test procedures. The hydraulics worked fine before the teardown for restoration so I left that system mostly as it was. I did replace the manifold tubes from the pump to the remote valve/cylinder block. I used new O rings at that location. I drained and cleaned out the cylinder block and installed a replacement filter unit. I did exterior cosmetics like replace the cylinder boots and actuator valve boots. I did not open the cylinder block. I did not go into the hydraulic pump. The pump stayed on the engine as it was. Now the problem, upon engine startup today for the first time, with new hi/tran fluid in the hydraulic system, the system seemed to work as designed for about two minutes. The fast hitch cylinder operated, the implement arms rotated forward and rearward. Then everything hydraulics came to a stop. Nothing works when levers are moved. One rock shaft is forward and one is rearward. The fast hitch cylinder is in the down position and does not move when the remote valve is worked. I topped off the hitran level and worked the control levers for 20 - 30 times. Nothing! To search out the problem I drained the fluid, took out the filter and it was clean and not plugged. I took off the manifold tubes between the pump and the cylinder block and turned over the engine to see what I could see. Nothing jumped out at me as a problem. Do I need to remove the pump and rebuild it? Do I need to take the cylinder block apart and rebuild it? Any suggestions to get the hydraulics working would be appreciated. Thanks in advance.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
