Re: SC Hydraulics Problem - Long
Posted by Janicholson on May 17, 2007 at 18:19:32 from (66.173.50.177):
In Reply to: SC Hydraulics Problem - Long posted by Skycarp on May 17, 2007 at 18:08:05:
The pump may have sheared the keway that drives it. If you had the steel lines off of the pump, and cranked the engine, the lack of any resistance or supply might have let it spin some. I would pull the pump off of the engine (simple to do and check the drive gear Key on the shaft. I have seen several with that failure. There may be a piece of gasket, or debris that got into the pump intake and wedged between the gears. Backing up the pump (make sure of rotation by looking at the drive gear in the opening while just bumping the starter. The pump turns opposite of that gear) may not clear the junk out of it. I would disassemble it to be sure it will not shear the key again. My best guess, JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
