Still no start
Posted by CNKS on May 19, 2007 at 18:26:25 from (204.249.178.32):
460 gas -- good spark, new plugs, good points and condensor, spark to plugs jumps 1/4" plus. Everything new or rebuilt inside block, new wiring harness, wired according to operator's manual, no corrosion, good grounds, etc. Carb cleaned and rebuilt, all passages confirmed clean. Static timed to TDC on #1, intake and exhaust valves closed, not 180 degrees off. 99% sure it is not an electrical problem. After much cranking, an occasional "starter speedup", it may have fired one time very briefly. The spark plugs are dry. Shouldn't they at least be damp after a lot of cranking? Apparantly not getting fuel to the plugs -- good fuel flow out of tank into carb. 460 has 2 piece mainfold with heat control valve. Valve was stuck open, I broke a couple of bolts trying to disassemble, messed up holes trying to get bolts unstuck, got new IH exhaust manifold first, but the holes were messed up in the intake enough that I had to get a new intake two. Intake is aftermarket. Does not line up exactly with the IH exhaust, but with the gasket, I don't think it leaks, not positive. IF I have a small suction leak somewhere where the intake is not perfectly fitted, will that destroy the ability for the gas to get to the plugs -- I have run out of things to do. Carb has been off twice, I have adjusted static timing from TDC to 4 degrees advance with no luck. The distributer and carb worked fine before disassembly. Any ideas are appreciated. Probably some dumb mistake I made similar to the one when I could not get any spark a couple of days ago.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
