Ballist Resistor
Posted by CNKS on May 20, 2007 at 18:27:07 from (204.249.178.32):
Or whatever the thing is called. What does it do on a 12 volt system? I thought they were for a 12 volt conversion with a 6 volt coil. I intially started the 460 with a 12 volt coil off my M which has had a 12 volt conversion with alternator, I did not wire through the resistor. The 460 is factory 12 volt with generator. Originally equipped with a resistor. I do not know the voltage of the 460 coil. The 12 volt coil off the M says on the coil "for use with external resistor", and was wired that way on the M. After I got the 460 running, I put the original coil back on and wired it thru the resistor. It would start, but the longest it ran was for about 5 seconds, started and died in a second or two several times. So I reinstalled the one from the M WITHOUT the resistor. Runs fine--will I burn the points, condensor or something or should I use the resistor? If the 460 actually has a 12 volt coil the answer is obvious, since it came that way, it is in the parts book. But why?
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
