Farmall Tractors Discussion Board
Generator not charging enough on Super C
Posted by Jim Smith Ft wayne on May 12, 1999 at 11:05:54:
Replaced wiring, regulator, gauge, Cleaned brushes, checked the connections inside of generator. Generator only
puts out about 2 1/2 to 3 amps. Belt is tight and
checked all connections. With lights on, generator
holds meter at zero amps. Problem is regulator doesn't always go into charge mode when engine
is idling fast. Appears not enough current to switch regulator into charge mode all the time. Question is how much current should the generator develope? And what can be fixed to make it work right.
Thanks
Jim
Post a Followup
: Re: Generator not charging enough on Super C
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
