Farmall Tractors Discussion Board
Re: Generator not charging enough on Super C
Posted by Rick K on May 12, 1999 at 13:19:13:
In Reply to: Generator not charging enough on Super C posted by Jim Smith Ft wayne on May 12, 1999 at 11:05:54:
This may be a dumb thought but, how much current is ammeter supposed to read under this condition? Are you actually having a problem with the battery going dead over time?
If it is not showing a discharge, then maybe all is OK. The battery only needs enough of a charge to recharge it. At the proper regulator voltage setting, if the battery is fully charged, it won't accept very much. 2-3 amps is a lot to stuff into a fully charged battery.
Read the battery terminal voltage when running with lights on. If it is 7ish volts, all it fine.
The only other thing I can think of is that the battery is dying/dead. A battery with high internal resistance will not accept much of a charge. If the battery is very weak, and the terminal voltage is up around 7 volts when running, but not accepting a charge, then the problem is in the battery, not the generator
Post a Followup
: Re: Re: Generator not charging enough on Super C
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
