Forget the cleaner. The governor is easy to work on. Get a repair kit from Case-IH, you also need a manual to tell you what to do, or perhaps someone who types faster than I do can type it for you. Adjust the main jet on the carb to 3-3.5 turns out. Be sure the carb is absolutely clean. Max is 5, but that is for maximum load which I doubt if you need. The only gear you should have trouble starting in is 5th. You can also check the compression, but it probably has to be well below 100 to act as you are saying.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
