Farmall Tractors Discussion Board |
Farmall 300 shifting problem
Posted by Hickory Hills Farms on June 11, 1999 at 05:48:18 from (209.166.172.222):
I recently purchased a Farmall 300 and I am having shifting problems. The tractor will sometimes stick in two gears at one time. When this happens I have to remove the shifter and realign the shifting forks. I was told before that this problem could be solved by adjusting the clutch linkage on the side of the tractor. Should I adjust the long or short linkage? Should I make them longer or shorter?
Post a Followup
