Farmall Tractors Discussion Board
Re: Farmall 300 shifting problem
Posted by Curt Cooke on June 11, 1999 at 06:15:11 from (207.75.224.250):
In Reply to: Farmall 300 shifting problem posted by Hickory Hills Farms on June 11, 1999 at 05:48:18:
The clutch has nothing to do with it. Two things will cure this problem. First, your shift lever is worn out on the end allowing it to move from one shift rail to another before the first one has become aligned with the second one. Next time you pull the shifter out examine the end. Building it up with weld may solve the problem, if you're lucky. The springs and balls that constitute the detents in the shift rails are probably also faulty making shifting between gears way to easy. The combination of sloppy shift rails and a worn end on the shifter lead to the problem you have.
Post a Followup
: Re: Re: Farmall 300 shifting problem
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
