Re: Re: Farmall-H timing
Posted by The Big G on February 07, 2002 at 17:26:22 from (204.227.178.35):
In Reply to: Re: Farmall-H timing posted by Mie ISW on February 04, 2002 at 18:56:00:
Thanks erkel3 and Mie ISW. to explain, when it first happened last year, I drained everything and cleaned plugs and carb. It ran fine. Then a month or so later, they did it again. This time it bent the rain flapper on the muffler - that is how hard it did it! BANG. Again, I got it going (This time I chained the cap down so they couldn't get to it.) To finally get it going, I had to disobey the book on timing procedure. When done I noticed the timing mark was off quite a bit from the original. O K No problem, it ran. Now through the time it took me to figure out a way to chain a tin can over the gas cap ( I need the tractor like everyday, so draining the gas becomes wearisome). They must have poisoned the gas quite a few times. It exploded three times and other times here is what happened. It starts like a champ. Runs a few minutes. Starts to ack like throttle too low You turn it up - it runs another few minutes. Now you are only chugging and throttle is opened all the way. You can go a few hundred more feet by choking it. Now it is GETTING GAS. The gas in the tank shows no signs of seperation- like water. So you drain the tank and carb- refill the tank with fresh gas. Remove plugs. You don't need to scrub them they look clean- you NEED to spray them with carb cleaner to remove a clear film. that film will come off on your finger and it won't dry. It must be shorting the plugs - because now it runs great again. Now a year has gone by. It started and ran great. It ran for a while, then suddenly it stopped like it hit a brick wall, not like you hit the kill switch. I changed gas, checked spark, retimed the mag ( because I flushed the impulse with kero to clean it- thinking that dirt may be keeping it from tripping). Won't fire up - it tried once in the many hours I tinkered. I know my timing isn't 180 degrees off because I corrected that accident the first day I played with it. Now after all that cranking, I checked the plugs and they are dry. THAT leads me to believe that the valves aren't opening correctly on the intake stroke. Only explaination I can figure for that is the timing gears broke or way spun out. Hope this make sense. I check this mail every few days so don't give up on me - I'm in the hills with NO PLOW tractor!!
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
