Re: Re: Re: Hey Bob M!
Posted by Bob M on April 10, 2002 at 12:53:16 from (66.66.72.246):
In Reply to: Re: Re: Hey Bob M! posted by Hugh MacKay on April 10, 2002 at 08:35:10:
Here's the deal: The 10SI regulator is programmed to light a warning lamp whenever the ignition is "on" and the alternator is NOT generating current. In addition, current passing thru the warning light circuit tells the internal regulator to "turn on" when you first activate the ign switch, since the regulator cannot directly sense whether or not the alternator is spinning. The resistor is merely a substitute for the warning light - without either a warning light or resistor (or a diode) the alterator will not turn on. Why does the motor run with the ign switch off and there is no lamp or resistor? When the ign is off, the regulator sends current BACK OUT the #1 line until the alternator stops generating current (i.e. it stops spinning). Since the ignition switch is open after you push it in, the only other path this current can follow is thru the ignition coil primary. If too much current flows (i.e. the resistor value is too low) it's sufficient to fire the coil, and your motor keeps right on running. The resistor or warning lamp limits this current to a value lower than is required to fire the coil - or in the case of the diode, blocks the current flow completely. Hope this helps...
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
