Farmall Tractors Discussion Board
A Hard Starting Farmall Cub
Posted by Scotty on August 10, 1999 at 09:56:55 from (204.183.211.45):
I have an 1948 Farmall Cub, that is getting really hard to start. It has a magnitto ignition that seems to have plenty of spark, the last time I tried to use the tractor, we had to pull the tractor to start it and it seems like the tractor is really hard to start after it gets hot. I have been running a Woods Belly Mower on the tractor for 2 or 3 months and I was wondering if I have sucked the life out of the motor. Can anyone tell me what the compression should be? The tractor won't start now, yet it has plenty of spark and after I crank on the motor a while trying to start it, and check the spark plugs, the plugs are wet with gas. I was thinking that the motor may not have enough compression to get fuel to the spark plugs but after cranking the motor a few times the plug seem wet with gas. Does anyone have any ideas? Thanks
Post a Followup
: Re: A Hard Starting Farmall Cub
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
